tial wastgate problem
Old Oct 19, 2010 | 07:44 PM
33bull's Avatar
my tial is overboosting i thought it was the hallman but i ran a direct line from the turbo source to the side of the tial and its still boosting 25+, then i pulled the wastegate apart the diaphram looks good no holes or tears it has dual red springs if that matters, thanks chad
Old Oct 19, 2010 | 07:55 PM
05VIII's Avatar
Try running with no hoses attached to the wastegate. I think dual red is 17psi. If you hold 17 with no lines running to it it should help to narrow the problem down.
More then likely you have a boost leak. Have you done a boost leak test? If not, do that first
