Surging problem with FP Black - help please
Old Nov 2, 2010 | 06:27 AM
  #31
EVO8LTW's Avatar
Originally Posted by tscompusa
just give it less preload. how big is your vacuum line going to the wastegate actuator?
I've played around with preload and it doesn't affect it. I can tune it out by lowering WGDC with the amount of preload I'm running now. The line to my actuator is around 5/32. It's not particularly big or small.
Old Nov 5, 2010 | 05:21 PM
  #32
High_PSI's Avatar
Originally Posted by griceiv
a boost leak would fix compressor surge. you need either less boost or more mass flow at the points you are getting surge. I'd work on the boost control and tune it out.
I'd suppose it's possible that if you had a leaky/fluttery wastegate you could get some surge that wouldn't otherwise be there , i.e. not enough energy going into the turbine wheel to drive the compressor causing the surge.
SO true. I just fixed all my boost leaks and now I have compressor surge . God damn fast spooling turbo!
stefenboy
Jan 12, 2016 08:55 PM
MajorMarvel
Jul 12, 2015 04:31 AM
boonkae
Mar 2, 2012 06:12 PM
BoosTyEVO
Sep 2, 2011 09:33 PM
nonschlont
Nov 5, 2010 05:31 PM
