car buckleing
Old Dec 1, 2003 | 06:39 PM
babyburner's Avatar
car buckleing
the car drives fine when I don't full throttle, but the second I full throttle, the car buckles on shifts. I have a turbo xs h34 with 3 shims, do u guys think thats the problem? also, when I shift, am I supposed to hear a bov noise cause i sure don't hear one. I didn't hear it with 1 shim either thou. THanks
Old Dec 1, 2003 | 06:42 PM
nastea's Avatar
hrmm its really bad when the bov doesn't open, are you sure your bov setting is not too hard?
Old Dec 1, 2003 | 06:49 PM
babyburner's Avatar
no, the buckleing isn't bad, just kinda like it doesn't wanna go, jolts me once or twice. any ideas?
Old Dec 2, 2003 | 08:54 AM
Secret Chimp's Avatar
I thought the bucking is boost surge....as in when you let off the throttle, the boost builds instead of being vented properly by the BOV....and you get a momentary bucking of the car.
Are you sure you have the BOV installed correctly? It is very easy to install most of em backwards....and if it is installed backwards the plunger inside the BOV won't vent boost properly.
SC~
Old Dec 2, 2003 | 09:19 AM
stevEVO8's Avatar
sounds like either your wastgate or your BOV is openening too soon and then closing again.
Ahh or it could be over boosting and hiting fuel cut but that would be very apparaent.
Old Dec 2, 2003 | 10:28 AM
evolutionist's Avatar
Re: car buckleing
I have the same BOV. I run 22psi when I am racing. My Turbo xs holds fine with no shims.
Your problem I would think is you have 3 shims in. This increases the spring tension so the valve won't open. With the valve not releasing this keeps boosted air flow against your thottle body even though you have let off the gas.
The idea is to have the spring strong enough to hold your psi and weak enough to let out the pressure when off throttle.
Take out the shims and you will find your problem more than likely go away.
I hope this helps.
Old Dec 2, 2003 | 02:23 PM
babyburner's Avatar
i left it with 2 shims... works much better thanks guys
