Car stalls after omni 4 bar install
Old Nov 17, 2010 | 01:22 PM
RevMoto's Avatar
Mods delete
Old Nov 17, 2010 | 01:27 PM
mrboost05's Avatar
did you just install it then try to start the car ? are you stock ecu or aem assuming you made the changes to whatever ecu you have check it for very tiny cracks and one point in time they had a bad batch it was the glue that was the holding it togther if that is the case contact them and they will send you a new one good luck.
Old Nov 17, 2010 | 01:40 PM
RevMoto's Avatar
just talked to my tuner and he is working on it for me.
Old Nov 17, 2010 | 03:35 PM
tscompusa2's Avatar
you must setup the rom to work with the omni 4 bar, and its also recommended to set evoscan to log as well since its a good boost reference in logging.
