Odd temp issue
Old Nov 22, 2010 | 05:58 PM
MitsuJDM's Avatar
Your case is odd and it does point to a sensor problem. However, I did hear of one other situation like yours. In that case so much air was in the cooling system that the sensor was dry and not indicating coolant temperature.
I'll try bleeding the system again. I drove the car to work today since the weather was warm. It had no problem keeping warm today. Slow to warm up but once it was there it was ok.
Originally Posted by CBRD
check to make sure all of your grounds are connected
if you leave the ground off of the intake manifold, it can cause erroneous coolant gauge readings on some cars
cb
I'll look into that, Chad. Thanks!
Raceghost
Aug 10, 2018 10:39 PM
CO_CReX
Mar 18, 2017 11:19 AM
SilentCool
Lancer Troubleshooting
Sep 22, 2015 05:57 AM
detroit pistins
Jul 26, 2014 12:46 PM
ethan169
Sep 10, 2010 07:06 AM
