stock turbo 11psi question Yes another
05 stock turbo, boosting 11psi (wastegate) with MBC installed im hiting 11psi fast like should, then boost creeping to 21psi @ 5200rpm ish, dont think there is a pill installed.
1. Do I need to have the pill installed?
2. **** MBC?
3. NO BOOST LEAKS
2. **** MBC?
3. NO BOOST LEAKS
When you install an MBC you need to eliminate the factory boost /vacuum hose assembly(which contains the pills) completely as well as eliminate the factory boost control solenoid(BCS). You must install your MBC with new hoses. Some MBC's already come equipped with precut hoses. Did yours? You don't want to reuse the factory hoses that contain pills, nor do you want to incorporate the factory BCS into the circuit.
well to rule out boost controller take a small vacuum line and run it off nipple directly to wastegate...go out run the car if boost still runs the same then your boost controller isnt the issue...otherwise see if you can take apart your boost controller to see if the ball and spring are maybe sticking...
as for the brand i would have posted the "Brand" if it was a brand name
your boost controller is turned down too much cuz if its only pullin 11 psi, but creepin up its tryin to run more boost so give it what it wants, and get tuned for it.....now did anyone mess with the wastegate preload...????
Try getting yourself a "Hallman", then do a boost leak test,... "Seach" and go from there.
Exactly how did you go about determining base WG pressure? Explain the proceedure that you followed, please. Did you just dial the knob on the MBC out all the way counterclockwise, or did you go the additional step further and adjust the WG actuator rod's turnbuckle tip until it just slid freely off and onto the peg located on the WG flapper valve's pivot arm?
