boost pipe jumping off cause turbo shaft to bend
Old Dec 18, 2010 | 09:52 AM
acssa's Avatar
Can a boost pipe jumping off cause a turbo to over speed and bending the shaft?
Please post your views on this....
Old Dec 20, 2010 | 06:31 AM
acssa's Avatar
bump
Old Dec 20, 2010 | 06:39 AM
evo 9 guy's Avatar
When you say "boost pipe" are you reffering to the turbo outlet, or some of the intercooler piping?
I doubt that it will cause the turbo shaft to bend. I have blown a coupler off (inbetween the intercooler and lower intercooler pipe) and my turbo is perfectly fine.
Old Dec 20, 2010 | 07:14 AM
Aby@MIL.SPEC's Avatar
imo, yes. as the turbo can easily overspeed. especially so if @ full chat. Generally you'll have a few blades bend before a shaft bending.... recheck to see if a few blades are bent over.
however, i have had a few pipes blow off & have never encountered a bent shaft or blades bending over.
Old Dec 20, 2010 | 07:59 AM
batty200's Avatar
Usually if the pipe blows off completely it will not hurt the turbo because the engine is not seeing the large amount of air which would feed the turbo the exhaust to overspeed it.
Now a car with a significant boost leak but not a total disconnect would allow the engine to get a lot of air and overspeed the turbo. Typically though overspeed will kill a bearing section before breaking a shaft.
If the shaft is bent or broken I would suspect compressor surge which can cause the turbo to suddenly stop or reverse rotation even with exhaust pushing on the turbine side. It could also be overheated and have caused fatigue on the shaft. Excessively high EGT's can kill a turbo fairly easily.
Old Dec 20, 2010 | 12:15 PM
acssa's Avatar
The one lower intercooler pipe jumped off 6 times...
Old Dec 20, 2010 | 12:17 PM
evo 9 guy's Avatar
You don't happen to have the INJEN piping kit do you?
Old Dec 20, 2010 | 12:51 PM
F0RSAKEN's Avatar
Man, people need to invest in good bead rolled piping and t-bolt clamps.
Old Dec 20, 2010 | 01:03 PM
acssa's Avatar
I do use the Norma T Bolt clamps...
It was a problem with the intercooler...long story...fixed it up.
But my turbo packed up and now they say it is because of a boost leak or pipes jumping off... never had leaks... just pipes jumping of at 29psi. 1200miles only and the HTA turbo was toast...
I have a sti9 with a GT35r and it had a major boost leak... for 3000miles... fixed and still running great with the same turbo
Old Dec 20, 2010 | 01:22 PM
BluEVOIX's Avatar
What is a "normal t-bolt clamp" ? Are you referring to the factory warm clamps or an actual t-bolt clamp?
If your using t-bolt camps with beaded intercooler pipes and your still popping off the pipes, then you might have oily residue that causes the couplings to slip off. I'd take it off and clean then with brake clean.
I had an issue with the coupler popping off the throttle body a while ago. It was because when I did my first clutch job a friend of mine used a little WD40 because we didnt have silicone spray to help slip on the coupling. Well that WD40 held its promise of keeping this slippery even with the t-bolts clamped to the point of almost breaking or cracking the TB inlet. I just used Brake Clean to wipe it clean and never had issues with it again.
Although you might not have sprayed anything oily on it, many people still run their pcv's recirculated and oil vapors will do the trick. Especially if you remove and reinstall a pipe that will break the original seal.
Hope this helps you.
Old Dec 20, 2010 | 01:37 PM
acssa's Avatar
http://www.normagroup.com/kunden/nor...N_78ZKTL_NORMA
Norma is is company that makes all kinds of clamps.... they were also involved in motor sport some year back.
Old Dec 20, 2010 | 01:42 PM
BluEVOIX's Avatar
Oh Norma not normal . I thought you meant normal as in regular etc.... Thats why I was all thinking what in the world do you mean by "normal" t-bolt clamps
rcheung's Avatar
The picture in the link shows a spring clamp and a worm clamp. T bolt clamps would be better. Companies have kits for both the evo 8-9 and 10 that comes with all the clamps you would need.
Old Dec 20, 2010 | 04:08 PM
BluEVOIX's Avatar
Thats just the main home page. They offer all sorts of clamp styles when you check out the other sections....
Old Dec 21, 2010 | 07:44 AM
acssa's Avatar
The problem is that a hose jumping of can stuff up a turbo...
yes or not a chance?
