please help!
Old Dec 6, 2003 | 09:25 AM
vtat9000's Avatar
Unhappy please help!
hi all, after i got my greddy type s yesterday i try to install it last night.every thing went good except the adjustment screw got loose and fall out.i couldn't find it but before installing the bov i already tune it all the way up. so i took get out for a drive for like 5min . the car run perfect then sunddenly there's this loud pop up sound and after that my car just die. i couldn't go past 3000 rpm at all. can does anyone know where i can get the adjustment to replace my old one. thanks for all your help
Old Dec 6, 2003 | 09:31 AM
Dale_K's Avatar
If you're lucky one of your hoses blew off. Check them all. If you're unlucky you might have just found the screw in someplace real horrible.
Old Dec 6, 2003 | 09:34 AM
blonde's Avatar
check the intercooler piping that goes to the intake manifold . i am pretty sure thats what it is.
Old Dec 6, 2003 | 09:37 AM
vtat9000's Avatar
i just put back the stock one.the car seem the be ok now. do u guys know how i can tune the bov using other method. thanks
Old Dec 6, 2003 | 12:14 PM
EvolvedDSM's Avatar
You can take the BOV to the hardware store and just pick up a nut and a screw there.
Old Dec 6, 2003 | 02:50 PM
WILDMAN's Avatar
Sounds like a hose popped off your intercooler. Same thing happened to me on my Grand National.
Old Dec 6, 2003 | 03:10 PM
vtat9000's Avatar
i will go check it out at pepboys but can my engine be damage if i use the bov without the adjustment bolt?
Old Dec 6, 2003 | 07:07 PM
3K's Avatar
3K
originally posted by: vtat9000i will go check it out at pepboys but can my engine be damage if i use the bov without the adjustment bolt?
I don't think it would damage your engine, but it can damage your turbo if it's not venting properly. To be safe I would put the stock bov back on and until you can get your greddy running right.
Old Dec 6, 2003 | 07:51 PM
EvolvedDSM's Avatar
It'll probably be too soft w/o any preload on the spring. Therefore, it'll leak under boost causing the turbo to work harder than it should trying to maintain pressure. If you aren't on it hard, it shouldn't be a big deal, but do get it taken care of soon.
Old Dec 7, 2003 | 12:12 AM
vtat9000's Avatar
should i be concern about the burnning smell after my car bog out when the upper intercooler hose got disconnect?i'm just really concern. thank you
