Compression Test Result - Pls Advise
Old Dec 30, 2010 | 03:07 AM
jameswwt's Avatar
Hi Guys,
ive done a compression test and all cyclinder is 12 bar except cyclinder no 3 which is 11 bar...
Is there a serious problem? As i will send my car for a re-tune soon.
Thanks
Old Dec 30, 2010 | 08:26 AM
jameswwt's Avatar
Anyone mind to share....
Old Dec 30, 2010 | 10:38 AM
Philthy748's Avatar
Do a leak down test, it'll tell you more about what's going on...
Old Dec 30, 2010 | 04:35 PM
jameswwt's Avatar
What is a leak down test and how to do it?
Thanks
Old Dec 30, 2010 | 05:12 PM
sirsol's Avatar
In a compression test, you want the numbers to be reasonably close to each other so yours are, within reason, similar enough that I would not be concerned.
As for the leak down test, read this:
http://en.wikipedia.org/wiki/Leak-down_tester
You essentially pressurize the cylinder and see how much/from where its leaking. It can tell you if you have problems with intake valves, exhaust valves, cylinder rings, etc.
Old Dec 30, 2010 | 07:06 PM
JohnBradley's Avatar
1 bar is 14.5psi I wouldnt be concerned.
Your results translate to-
#1- 174
#2- 174
#3- 160
#4- 174
That amount of variation can be because of several possibilities unrelated to failure of components. If it were down around 8 or 9 bar I would be concerned.
Old Dec 30, 2010 | 07:19 PM
05blue8's Avatar
^^ listen to him
Old Dec 31, 2010 | 03:01 AM
jameswwt's Avatar
Thank you so much John Bradley
Old Jan 3, 2011 | 12:00 PM
Jersey Dino's Avatar
2006 Evo IX. My numbers today were 135,145,145,145. It looks like these are lower than other cars but there is a similar disparity in numbers. What is your take on that?
Old Jan 3, 2011 | 04:55 PM
LV///R's Avatar
99% sure the IX's compression numbers are lower than the VIII's. If you search a bit, you'll find out your numbers are likely normal.
Old Jan 3, 2011 | 05:34 PM
I will def search when I'm home later. It's a bit tedious from te phone but figured I would take a shot and hope to get an answer before then. Thanks dude
Old Jan 3, 2011 | 06:01 PM
LV///R's Avatar
https://www.evolutionm.net/forums/5919468-post66.html
There you go. I'm such a nice guy!
Old Jan 3, 2011 | 06:14 PM
Awesome dude thanks so much! Maybe the clock won't drag at work now that the suspense has been lifted.
Old Jan 3, 2011 | 11:45 PM
rob_96's Avatar
you are fine... just enjoy the car. Why did you do a compression test in the first place
Old Jan 3, 2011 | 11:51 PM
L888Apex's Avatar
whew thank god I did a compression test on my car and it was 135, 145, 135, 145(or some combination of that)awhile back and I was scared.
