Clutch Problems need some advice
Old Jan 8, 2011 | 06:35 AM
Night12000's Avatar
I have a 2003 evo an yesterday driven down the road an the clutch pedal went to the floor an stuck! pulled the pedal back up and the pedal was so stiff it wouldnt move btw i check the fluid an it was fine.so what next?? im stuck just put a neww clutch in a year ago sooo help me plzz??
Old Jan 8, 2011 | 07:09 AM
milford's Avatar
this thread pops up at least once every 5-6 days. slave
Old Jan 8, 2011 | 07:15 AM
Night12000's Avatar
slave what master cly are u sure an do i have to drop the trans and everything to change it..
Old Jan 8, 2011 | 07:23 AM
milford's Avatar
you do not have to drop the trans to fix it. its very easy. follow the line from the master cyl to the slave...its on the trans right under your intake tube area. un bolt it and inspect it and also look at your clutch fork. The fork should be centered in the grommet. also do you have a twin disc by chance
Old Jan 8, 2011 | 10:33 AM
Night12000's Avatar
no just stock clutch
Old Jan 8, 2011 | 10:34 AM
Night12000's Avatar
do u have a pic of it or somethin i can see it would help
