How many of you not running oil squirters in your 2.4l
You should have had them added when you built your motor....no sense in worrying now (as worrying does no good)....just wait until your next build....
Frankly, it is so cheap to do (when the motor is at the machine shop) I just don't understand why folks don't do it 100% of the time...
Mike
I'm not being a smart a$$, I am just trying to understand...
I doubt anyone would have an issue without running oil squirters on a 2.4L, but to me it seems like it would be better to do it.
I have ran many motors starting from 2004 with no oil squirters and have not seen anything that would make me want to run them.
What I have seen is most of the forged pistons end up hitting them and you have to bend them to clear and if its a high rpm race motor most of the time they will break off and fall in the pan. Lucky the way they break does not seem to cause any problem.
Not sure if its a no BS shaft race motor thing or the fact that you have to mod them to clear is why they break.
Mikey
READING COMPREHENSION is your friend Rock
I never said they are required. I said I don't understand why someone would not add oil squirters on a 2.4. You really should read (and study ) a bit more and maybe you'd understand why I have the OPINION that oil squiters on a high performance engine are a good thing.
The reason many drag racers block off the squirters is to reduce drag. That said, for a street car or race car (non drag), squirters will help cool the piston, make your car less prone to knock, and help preserve your motor. Are the squirters needed for a street car, IMHO no, but I'd add them as extra safety for a few hundred dollars...
.I never said they are required. I said I don't understand why someone would not add oil squirters on a 2.4. You really should read (and study ) a bit more and maybe you'd understand why I have the OPINION that oil squiters on a high performance engine are a good thing.
geeze, you guys live in such a black and white world. "if it doesnt break, it must be fine!" there are pro's and cons of oil squirters. are they "needed"? no. are they going to cause problems? no. are the pistons and rings going to last longer with them or without? probably longer with them. on your average street car they are obviously not "needed" but if i was building a road racing car, you bet your *** i would run them.
Okay since you wanted to bring up the pistons/rings... In build motors what part usually goes out first? It is the bearings not the pistons/rings. Why would you take away oil from a part that is statistically known for failing first?
Mikey
Mikey
sometimes its bearings, sometimes its ring/piston wear, sometimes crap just happens and something random breaks. im all for eliminating as many wear/failure points as i can.
like i said, they have their purpose. ams uses them in the 2.3rr but not the 2.1 drag motor. it all depends on the intended purpose of the motor. im most likely not going to run them either.
imo, i would just do the balance shaft delete, buy a kiggly hla, and keep the squirters. the first 2 raise oil pressure a bit and squirters are beneficial, especially if they are already installed.
Guys - We are all trying to make these motors as best as possible. Let's try to help each other out however possible.
Mikey - Thanks for your reasons for not using squirters. As I acknowledged your reasons are why drag racers don't use them. For those of us that road race (or did) the more common practice is to use the oil squirters. (Thus my bias.)
Aaron - I totally agree that an engine builder would have to ensure that the the piston does not hit the squirter. I also believe that most would be fine running without the squirters. I just feel for a road race car or one that is pushed really hard for long runs, the squirters would be added benefit.
Rockman - I was just saying that I never said squirters are required and then you posted saying I did...It's all good.
I honestly still wouldn't use oil squirters if I road raced... A lot of road racers lose motors with bearing failures due to oil starvation! I would be willing to bet most of the failed built blocks had oil squirters. I can't fathom the fact of taking oil and throwing it on a piston that is forged. Just my .2 and you guys are obviously going to do what you want. Even a lot of people think that the oil squirters in the 2g is what causes crank walk... Marco which has one of the fastest 4G63 in the world say they can cause crank walk. Every high hp built motor I know of doesn't have oil squirters, R34, 2JZ, every built Honda etc... It is just not needed on Forged internals.
Mikey
Mikey
Well the ZR1 and the 911s have them (as do most of the crazy exotics that most have never heard of), but I am guessing that is because they run dry sump systems. The aforementioned all have forged internals too. Maybe that is the issue, most of my experience has been with cars with dry sump setups.
