Fluctuating boost...too much wg preload?
Old Jan 23, 2011 | 02:13 AM
  #31
BEISSEN's Avatar
Originally Posted by raasfaas
Yea it looks like the 64mm cover is a hit and miss in regards to surging.
I'm definitely going to get the 84mm cover, I'm not too comfortable with the amount of surging I'm having. For now I'm just going to port the O2 housing and keep the wg preload conservative so as to reduce the surging. When I get the cover I'll probably just take the turbo off at the same time and have the wg ports opened up a bit like you and sparky suggested.
Yes I saw your thread about the single scroll housing, very interesting...I'll be following it to see your results
Im having creeping issues with the 84mm Raafaas so get ready the Red witht he 84mm loves to flow so port the o2 and get the cover. I am ordering a new o2 I have the EPM v2 Dump and FP said with the Hole for the flapper its to small and not allowing proper opening and thus creep. I am running the 18psi WGA as well. I am going to order the MAP o2 houseing FP siad it looked good as well as the JM Fab parts fyi.
Old Jan 23, 2011 | 11:59 AM
  #32
raasfaas's Avatar
I just ordered the 84mm cover and should be getting it in a few days. Yea, I was told about the possibility of creeping with the 84mm especially with the amount of preload you have (like Mikey stated above).
How much preload are you running?
I personally like the quieter sleeper approach so I'm trying to avoid the dumps...I'm going to port my O2 housing merge hole like sparky suggested and see how that goes, I've already followed their suggestion of cutting of a couple threads off the actuator rod and so far so good, I'm not creeping with the 64mm.
StevenTranSSK
Aug 13, 2016 02:56 PM
black E
Evo X Dyno Results
75
Feb 21, 2016 01:28 AM
black E
11
Oct 21, 2014 04:34 PM
grimrpr9
For Sale - Part Outs
11
Oct 4, 2012 03:33 PM
joeyhauser
Nov 5, 2009 07:18 PM
