Wazmunstr - My transmission rebuild thread
Old Feb 1, 2011 | 07:21 PM
dan08's Avatar
Very good information. I don't know if I have the guts to try this.
Old Feb 1, 2011 | 07:43 PM
wazmunstr's Avatar
np dudes! the fsm is a very good tool. the 5 speed is a very simple machine to work on man lol.
I called up jack's today in hopes someone could answer my question about the shim but they never called back. I'm thinking of just keeping it the way it is. there isn't any play at all and that's all I'm worried about.
Old Feb 5, 2011 | 03:29 PM
wazmunstr's Avatar
Another update!
Old Feb 7, 2011 | 06:04 PM
dck47's Avatar
Originally Posted by wazmunstr
Another update!
Great news!
Got any tips on how to remove the trans/transfer case assembly??? That's what I'd like to know!
Old Feb 7, 2011 | 07:50 PM
wazmunstr's Avatar
I followed this exactly, just so I didn't miss anything.
http://www.evomoto.com/tech_articles..._article_id=27
I purchased a box of zip lock bags, and every time I came to a part to remove, I threw the bolts and nuts and what not in the bag and labeled it. It made my job of putting the car back together much easier because I knew what went where!
Old Feb 9, 2011 | 07:36 AM
03evilution's Avatar
From: Poughkeepsie NY, Central Jersey Shore, Fort Meade MD
nice write up man
Old Feb 19, 2011 | 05:41 PM
wazmunstr's Avatar
Final update!
Old Feb 19, 2011 | 07:03 PM
project_skyline's Avatar
I give it 5k miles before it needs another rebuild. Lots of members have rebuilt their own transmissions with bad results, very few have had good ones.
Whats your experience with building transmissions?
Old Feb 27, 2011 | 03:55 PM
wazmunstr's Avatar
None. First time. I followed the fsm, along with help from shops, and members. I'll let you know in 5k miles. I'm at 1k.
Old Feb 27, 2011 | 03:57 PM
wazmunstr's Avatar
Btw I only replaced the input shaft bearing, nothing else. That's a very simple job. Either way, see you in 4k miles!
Old Apr 20, 2011 | 06:54 AM
ccb156's Avatar
had the same damn problem with my '03 gsr. blew the input shaft bearing after a rough launch with my exedy twin. Ended up having to do pretty much this exact same thing. Wish this thread would have been around then! This is great info for anyone rebuilding a tranny.
Old Aug 19, 2011 | 08:19 AM
wazmunstr's Avatar
New update!!! Over 5k later.
Old May 30, 2012 | 08:55 PM
wazmunstr's Avatar
Thought I would revive this thread and update that it has now been 17k miles since this and I can safely say it works fine !
Old Jan 20, 2013 | 05:36 PM
gpfury86's Avatar
You have any pictures of the sliders and synchro gear wear. I just wonder how it compares, my 3/4 looked like this and it was shifting pretty poorly at high rpms.
Then heres a few pictures of my disassembly and reassembly process
Old Jan 21, 2013 | 07:02 AM
blowngasket's Avatar
i just read this, did he not preload the output shaft with shims? output shaft and Center diff are preloaded with shims you have to use solder and crush it measure it and use the right shim for the preload, the input shaft has end play. i also drilled a couple holes in my shafts for extra oiling to a couple bearings.
Take a look at my thread about transmission rebuild, you can see what worn parts look like.
Standard value:
Input shaft end play: 0.05 − 0.17 mm (0.0020 − 0.0067 inch)
Output shaft preload: 0.13 − 0.18 mm (0.0051 − 0.0071 inch)
Center differential case preload: 0.05 − 0.11 mm (0.0020 − 0.0043 inch)
