No compression on rebuilt motor? Will not start.
Old Jan 26, 2011 | 11:15 PM
achilles3000's Avatar
Originally Posted by Lucas English
Not sure if you were the one that called the shop the other day.
Anyway the person I talked with said that they broke a crank pulled the motor and never took the head off and tossed a new crank in. After the conversation had me thinking maybe they put a 2.0 crank in would would kill the compression if it was ment to be a 2.3.
If I feel like I have flooded a motor out I will undo the injectors and pour about a table spoon worth of oil in each hole and Crank on it for a little while with the plugs out. Also new plugs are key. Once plugs are real wet even when dry and clean they will not be right. Its amazing the amount of time I have seen people spend trying to make car start and it was only a fresh set of plugs away.
Plugs did wonders for me last week lucas..Good post.
Old Jan 26, 2011 | 11:31 PM
okevolutionVIII's Avatar
I still have an extra set of plugs. Just using the using the wet ones until I get the compression figured out.
Thanks to everyone for their input so far
Old Jan 27, 2011 | 12:07 AM
BISHILVR's Avatar
You have valve problems.
Old Jan 27, 2011 | 12:16 AM
javicracer's Avatar
Did you disconected the crank cable for doing the compression test?!?!?!
Old Jan 27, 2011 | 04:52 AM
KX250Fmotoracer's Avatar
what?
Old Jan 27, 2011 | 02:42 PM
Never heard of this before, never had to do anything out of the ordinary to do a compression test on the Evo or any other car.
Old Jan 27, 2011 | 02:53 PM
rgeier11's Avatar
Obvious timing belt problem is obvious.
Old Jan 27, 2011 | 03:13 PM
How is this? Everything is in time. I'll take pics to rule this out.
Old Jan 27, 2011 | 03:55 PM
TheMadScientist's Avatar
Sounds like bent valves. Once you have ruled everything external of the engine out, Pull the head and have it checked. Also make sure the pistons are getting to TDC to make sure the crank is the correct one (I'm sure you did this but just wanted to throw that out). Sounds like bent valves to me.
Old Jan 27, 2011 | 04:22 PM
If the leak down test shows anything leaking past the valves, I will pull the head. But as I said in the 1st post, the valves and seals are new and I did lap each valve to it's port, ran some gas through the ports and none leaked.
Old Feb 13, 2011 | 07:10 PM
Edit
Old Feb 14, 2011 | 02:36 AM
Chadwick4477's Avatar
Results of the Leak Down Test??? Because I agree with "TheMadScientist" it most definitely sounds like bent valves. But can't speculate until you complete that leak down test. None the less GL with this motor builds that have frustrating issues like this take a toll on you stress wise been there done that.
Old Feb 14, 2011 | 06:44 AM
VRSF Tiago's Avatar
Not sure why you're worried about fuel or spark when the culprit is clearly an issue with compression.
If you're not getting ANY compression you're timed incorrectly or you're having valvetrain issues. That's assuming the motor was built correctly.
Fresh motors won't give you 160-170psi off the bat but they'll sure as hell beat 0 psi without gobs of oil in the cylinders.
Old Feb 20, 2011 | 09:19 PM
I got a leak down tester but before I went any further with that, I decided to degree the cams as I've read about issues with Revolver cams. The head and block were decked so I expected the numbers to be off anyway. Here's the readings I got.
Intake:
http://i252.photobucket.com/albums/h...n/IMG_0485.jpg
Exhaust:
http://i252.photobucket.com/albums/h...n/IMG_0488.jpg
Would the intake cam being that much off keep the car from starting?
Old Feb 21, 2011 | 10:09 AM
Any opinions?
