New FP 71HTA?!?!?!
Old May 25, 2011 | 12:31 PM
  #136
HHIX's Avatar
buy it and give us a review
Old May 25, 2011 | 07:09 PM
  #137
Nashou66's Avatar
Just found this thread, I bought one after talking to one of the guys at FP who suggested it to me back in Jan. My EVO VIII MR turbo seized and it was my daily driver so I couldn't install it till i had a second vehicle to drive. My parents go to aruba for all of feb to march so I had their Jeep to drive for 5 weeks. Work kept me away from installing it till late Feb. It definitely is a nice improvement over Stock on the 8. I had to buy the fluid lines to make it fit and also I decided to go with an 18psi actuator which i installed wrong where the waste gate was always closed never allowing boost of so i didn't do much full WOT this way. Obviously I didn't want my engine to explode . It was also put on a completely stock car with all stock gauges so i couldn't even measure correct boost, the stock MR gauge was getting buried on the couple runs I did at full boost till fuel cut made it feel like i hit a brick wall. So it going way past the 1.5 bar mark.
Once I fixed how the WG was installed the car drove much better, and peak's boost at about 24 with no tuning on stock exhaust and intake etc. Then Fuel cut comes in with the brick wall feeling but not as sever as before. It builds boost pretty quick and one thing it does better than Stock is it pulls hard way up to 7000rpm. I bought all the cables for logging and a WBO2 and AEM boost gauge. So once i have time and read up more on logging and add a map sensor or some how figure a way to use the AEM 3.5 bar map sensor analog out to feed into the ECU i'll get more accurate boost reading as the logging is showing 47psi with the stock 1bar MAP , obviously its wrong. Also I am still learning the ECU flash and EVOscan stuff so I could be doing something wrong.
they also told me in testing they hit 470 HP to wheels with this turbo.
But I do recommend this turbo for those on a tight budget, even with the 150 bucks for the install kit for the 8 its worth it.
Athanasios
Old May 25, 2011 | 08:07 PM
  #138
blkmkIII's Avatar
wtf I thought this was like $3xx? not $650, why not go hta green for another $45?
Old May 25, 2011 | 08:49 PM
  #139
Nashou66's Avatar
Huh? the green upgrade with sending in your turbo is 869.
http://store.forcedperformance.net/m...=Turbo-Upgrade
with the 71HTA they send you the cartridge. Easiest way to upgrade. No removing the entire Turbo. buy it they send you the cartridge instal it and send back the core if you want another 100 off. I kept mine, Might try to rebuild it for the fun/learning aspect of it.
the white which is a smaller turbo is 45 dollars more, maybe you meant that?
Athanasios
Old May 27, 2011 | 10:50 PM
  #140
blkmkIII's Avatar
Idk what the hell I read! lol (I was thinking wow green price went down nice!)
Old Aug 14, 2011 | 05:28 PM
  #141
211Ratsbud's Avatar
I have one will post results soon
Old Aug 24, 2011 | 10:47 AM
  #142
sokaroza's Avatar
I got it installed all basic bolt ons made 400 HP and 394 tq at 28 lbs boost on mustang dyno. It was about 94 degrees out at 11 pm when we did it too. Spoils fast as Hell. Want to up boost but car starts doing stupid **** like high rpm misfire when shifting so left it at 28 lbs. Runs great where it is but always find myself wanting more.
Old Aug 24, 2011 | 10:50 AM
  #143
sokaroza's Avatar
Meant spools fast as Hell this phone doesn't know the word spools so changed it for me. Great turbo!!!!
Old Aug 24, 2011 | 12:53 PM
  #144
BigT's Avatar
Can you elaborate? What type of fuel? Other mods? Who tuned it and at what facility?
Old Aug 24, 2011 | 01:02 PM
  #145
SOEuro's Avatar
do you go to the vegas meets?
Old Aug 24, 2011 | 03:53 PM
  #146
sokaroza's Avatar
Ya sorry bro. So e85 fuel. Got pte 1200 cc injectors, cosworth 272 intake and exhaust cams, ets 3.5" intercooler with ets upper and lower pipes. Forge manual boost control. Tanabe concept g blue turbo back exhaust. Megan ported o2, Muse ported exhaust manifold. Dougs dynopower tuned built and tuned.
Old Aug 24, 2011 | 03:56 PM
  #147
sokaroza's Avatar
Arp head studs too. Fp intake for 84 mm surge housing. Cone filter. Single walbro 255. Think that's it.
Old Aug 24, 2011 | 03:57 PM
  #148
sokaroza's Avatar
Synapse bov too
Old Aug 24, 2011 | 04:42 PM
  #149
211Ratsbud's Avatar
I will have similar supporting mods, except with stock intercooler and o2 dump, and be running 93
Ill be trying to go speed density aswell on the stock ECU, but may end up starting with MAF
Old Aug 24, 2011 | 08:02 PM
  #150
sokaroza's Avatar
When u doing it???
