BBK Full compressor surge at only 27 psi?
Old Mar 15, 2011 | 02:12 PM
  #91
RSMike's Avatar
Originally Posted by CBRD
boost leaks can cause detonation
+1
I had a stock turbo with a large boost leak on the turbo compressor outlet.
It still made power, but we had to pull out 2-3 deg of timing in the top end to get rid of the detonation.
It wouldn't go over 4psi on the boost leak test >.< So it was a BIG leak
Old Mar 15, 2011 | 08:35 PM
  #92
Mosaic's Avatar
So a big enough boost leak overworks the turbo into suboptimal efficiency producing a hot air charge driving detonation in spite of lower boost?
Or is it more a medium sized leak allows the turbo to still make the boost tgt at a much hotter air charge?
Old Mar 15, 2011 | 08:56 PM
  #93
Synapse's Avatar
The principle is very simple, if air isn't going into the engine, then it isn't going out the exhaust. If a like volume isn't going out the exhaust, then there's no additional energy to drive the turbine.
The degree of leak doesn't matter with regards to the turbo. The turbo's shaft speed doesn't change significantly with the leak. You won't overspin the turbo. Most anyone that claims that is making those claims based on conjecture. Someone doing testing on a steady state hot gas test stand can overspin turbos all they want by unloading the compressor since the test stand can keep feeding energy to the turbine. But, I'd like to see someone try that on an actual ICE in a test cell. Now, introduction of NOS, or additional fueling on a CI engine, two-step=external combustion, that's plausible for overspinning turbos. However, simple boost leaks without any other changes, not gonna happen. The negative effect is more a function of thermodynamics in an ICE and to some extent enthalpy, not so much rotordynamics. All I can say is that the engine, not the turbo, is put into conditions of inefficiency that lead to significantly reduced VE and primed for detonation.
Old Mar 15, 2011 | 09:32 PM
  #94
Synapse's Avatar
If you have a turbo thats designed to run at 28psi.. peak efficiency- and you go over that- (because of say a 10 psi leak) you are now operating at 38psi at the compressor outlet- which moves the turbo out of it's efficiency range and causes hot air- which in turn warms the entire intake charge- and you now are causing detonation etc!
Sorry dude, it doesn't work that way. Show me data or reference to an academic journal that supports this.
Originally Posted by Synapse
There are plenty of factors that make turbos die. I'm not trying to draw any conclusions. However, over spinning via boost leak is not plausible at all.
If the compressor wheel is contacting the compressor housing, it is thrust loading related, and can be anything from a nut coming loose, bad thrust bearing, or coming out of balance.
One thought, however, with regards to the compressor wheel contacting the housing. I'm wondering if it is possible that the sudden unloading of the compressor wheel, via charge piping popping off, may produce some instantaneous thrust that compromises the thrust bearing and that's why it contacted the housing. But not because it overspun. Then again, the turbo should have been able to take that since that's what you essentially do every time you let off the throttle.
Food for thought: the turbo system on my test car, has a little button that creates an instantaneous boost leak any time I want it, boost rising, boost falling, peak boost, low RPM boost, high RPM boost, whatever. Any time you activate the leak, the turbo speed will drop to the RPM that corresponds with that given pressure ratio +- 500-1000 RPM.
Old Mar 16, 2011 | 03:53 AM
  #95
EVO8LTW's Avatar
Chad, I feel badly that this thread has become a thorn in your side. It was never meant to be a negative thread. If it's any consolation, I love the turbo. It spools really quick and pulls hard all the way to the top. Just the ticket for the type of events that I'm planning to do.
evoch3n
104
Apr 5, 2018 11:13 AM
jameswwt
44
Jan 30, 2014 08:10 PM
JV21804
19
Oct 30, 2013 11:03 PM
discopotato03
Jun 21, 2010 04:18 PM
mitsuevo803
392
Feb 22, 2010 07:25 PM
