Help! Identify these GSC cams.
Old Feb 9, 2011 | 07:46 PM
ProjekEvolution's Avatar
I need help identifying these GSC cams. Came out of an Evo VIII. Are they S1's, S2's or something different? Would be nice to know what I got and their duration, lift ect... Any help would be appreciated. Thanks!
Old Feb 9, 2011 | 09:21 PM
still*boostn's Avatar
Call GSC!!!
Old Feb 9, 2011 | 09:36 PM
achilles3000's Avatar
There S1 cams S2's have more yellow paint strips not blue all over.
Old Feb 9, 2011 | 09:38 PM
ch1215g's Avatar
SUSPECTED SCAMMER
why do they say 2 on them tho?
Old Feb 10, 2011 | 05:35 AM
PsychDr. HN$'s Avatar
I dont recall my S2''s having "GSC" marked on them. I think one of them had a "2" on it though. Are those older GSC Cams?
Old Feb 10, 2011 | 07:37 AM
Gary@MellonRacing's Avatar
Is that steve rossbach on the newspaper ?
Give Greg a call at GsC and he should be able to give u an exact answer buddy ...
Thanks
Old Feb 11, 2011 | 08:53 PM
Solved! Got w/ Greg @ GSC, he asked for the grind code which is in very fine print opposite of the JH93 stamp. It was stamped PPA which he said is the grind code for S1's. So...
PPA=S1
PPB=S2
PPC=S3
Maybe this will be useful for someone else down the road. Thanks for the help!
Old Feb 11, 2011 | 08:55 PM
limp_noodle's Avatar
did he tell you how to identify an s2 cam?
Old Feb 12, 2011 | 01:49 PM
Yes , it's in my post.
Old Feb 14, 2011 | 07:25 PM
thanks.
Old Apr 11, 2011 | 03:04 PM
vortecd's Avatar
Would be nice if they would just put the part number on the cams.
My new GSC S2 274 cams are stamped PPG
Old Apr 12, 2011 | 12:08 PM
GregGSC's Avatar
PPA=S1
PPB=S2
PPC=S3
This is not correct. these numbers change as to the batch that they are run in.
Old Apr 19, 2018 | 03:14 PM
2rbolag's Avatar
Excuse the thread revival as I’m also curious. So if the numbers change according to the batch, is there a sure way of confirming? I just got a set for my evo 8 and it says PPB. Do I have a set of s2’s or something else?
Old Apr 20, 2018 | 05:38 AM
blackline's Avatar
5 Year Member
It might be best to call GSC as the PPX changes for each batch.
