Forge Adjustable Wastgate correct adjustment
Old Feb 26, 2011 | 02:46 PM
gallas's Avatar
I have had a Forge adjustable wastgate on my car for quite awhile now and doing a transmission pull noticed it was installed very lightly holding the flapper shut. does anyone know how to properly gage how "tight" the flapper should be held. Also I assume that all i would have to do tuning wise is adjust my WGDC to match what boost im looking for after the adjustments? Thanks in advance to anyone who can help.
Old Feb 26, 2011 | 02:52 PM
Evoryder's Avatar
https://www.evolutionm.net/forums/7813396-post77.html
your welcome.
Old Feb 26, 2011 | 03:02 PM
Evoryder's Avatar
Tip:
pop off nipple hose that leads to wastegate actuator. Apply air from compressor to it so that it moves the wastegate arm easily. This allows for easy adjustment. 15-20psi should be enough pressure for the forge to open.
Old Feb 26, 2011 | 03:11 PM
BLKCarbonEVO's Avatar
^ Thank you. Thread Closed.
Mikey
