Can Evo 4 5 6 Use 6.5 TME Center Differential???
Hi Guys,
can an Evo 4 5 6 Use 6.5 TME Center Differential???
My friend Evo 6 got weird sound while making turn after swapping a TME center diff.
At first he thought is the driveshaft problem but after replacing the driveshafts the sound still persist.
Lastly, does a Evo 7 8 9 transfer box fit Evo 4 5 6?
Can't answer for the early USDM VIII non-ACD transfer boxes, but none of the VII> ACD ones would be compatable.
Do they back themselves out?
I've got knocking to the right only also in my car (evo 5 gearbox, evo6 LSD transfer), it almost sounds like a CV but less clicky.
Cheers, Mike
Yes they either shear or come loose. Find an open car park and put on full righthand lock, drive in a circle slowly and you should hear it clonk. If it's the diff bolts, get someone to watch the wheel driven by the driveshaft that goes into the transfer case, you can normally see the movement in the wheel back and forth.
evo 6 transfer case
