evo 9 spark plug choices which ones?
Old Jul 7, 2012 | 10:12 AM
17579EVO9MR's Avatar
Any updates with these plugs. I like ngk plugs, but for one step colder and all but $200.00, are the denso's of same quality? I am at 701 on buschurs dyno, on e85
Old Jul 7, 2012 | 10:41 AM
tiggeryellow1's Avatar
Veteran: Army
Originally Posted by Gobbldok
Im currently running IHK22's and find that the car misses sometimes when i turn it up to 25 PSi. Its fine when i put it on actuator pressure. I only just got the car recently and im told that the plugs have been gapped.
Im now looking into these NGK r7437-8 or some OEM ones.
My question is, do you have to specify a specific gap with either of these?
YUP! The gap is usually going to be dictated by how much boost you're running and your particular turbo set up. On stock Evo's running somwhere between 17-20 PSI I believe the gap is .028-.031; 20-25 PSI = .025-.028; 25-30 PSI = .022-.025; 30+ PSI =.018-.022.
(Disclamer)
Now getting away from the what works on the VIII vs. IX argument, these are just plug gap settings that I have seen numerous Evo owners use on their cars by virtue of the boost levels they were running and by no means am I attempting to tell you this is what will 4 sure work on your set up. This is just my .02
Old Jul 11, 2014 | 11:04 PM
ConnorEvoIXMR's Avatar
yea
The nos brand works to. im 26psi on stock turbo as well. youd have more ps on a black.
Originally Posted by joseph143
i have the mods listed in my sig... i ran the 150dollar 1 step colder ngks for like 4 months before the fouled out. but before and since i've ran stock plugs from the dealer and they work great... gapped to .022/3 not one issue...
so far theyve put up with 31psi on a stock ix turbo, and 28 psi on a green... methanol... 110octane... and heavily enriched 91 with 2 large cans of 108turbo octane booster. which btw is the only booster i've found to actually effect knock just fyi
evo9powerr
22
Jul 7, 2014 09:38 AM
Hi Im Vinh
11
Aug 26, 2013 09:20 AM
bbyevo8u
Jun 17, 2011 11:53 AM
usernameinuse
Dec 13, 2010 01:26 PM
john blaze
Mar 9, 2010 05:05 PM
