Stroker Problems evo9
Old Mar 21, 2011 | 09:14 PM
dragers's Avatar
Originally Posted by JC evo1
is the head toast also? What method were you using to check for detonation?
here's a pic of a Wiseco hd 9:1 94mm stroke 150mm rod for comparison, i dont know much about piston design but the top land looks to be alot bigger than your cp's.
your piston looks much better than the one I had,
I had no method of checking detonation, only thing I know is that fuel ratio was ok
, and other car with stock rods and the same parts has worked ok with the same spark advance table
I use an aem ecu, dont know how to check detonation with it
thanks for the input
Old Mar 21, 2011 | 10:32 PM
RSMike's Avatar
you're using a full custom engine, 30psi, race gas worth $$$ per litre and you have no form of knock/detonation detection?
oh boy
Old Mar 22, 2011 | 05:10 AM
Bcity's Avatar
oh boy
what do you use mike ?
Old Mar 22, 2011 | 05:18 AM
sirsol's Avatar
+1 for detonation, the small white particles you see built up on the piston are usually tell-tale signs of detonation.
Old Mar 22, 2011 | 11:16 AM
RSMike's Avatar
i get a professional tuner to tune my car.
he uses this
http://www.linkecu.com/products/Tuni.../g4-knockblock
Old Mar 22, 2011 | 11:25 AM
browningderek's Avatar
100% detonation!! cause unknown......
Old Mar 22, 2011 | 01:30 PM
Mark S's Avatar
No geometry problem it worked fine up to 22psi
when I used 30psi with q16 , the 4 pistons broke
fuel mixture was 11.4 to 1
I wouldnt recomend using 156mm rods with 94 mm stroke
because of my bad experience
On that pict and the other one it looks like dett, Can you take a pict of the other pistons for a better look.
Mark
Old Mar 31, 2014 | 04:45 AM
tupac1's Avatar
Old threadi know but op never said if valves were hit or not.
Can you verify Thanks Op
Old Mar 31, 2014 | 05:00 AM
evolve_VIII's Avatar
The valves should not have hit. The debris from the piston may have hit the valves and seats.
Old Apr 1, 2014 | 03:53 AM
tupac1's Avatar
Hi mate just wandering if you know this for a fact.only reason I'm asking is I just bought Manley stroker pistons and I'm planning to get Manley 156mm rods to go with my 94mm crank. Do you know someone running 156mm rods and stroker pistons with 94mm crank?
Old Apr 2, 2014 | 12:23 AM
KGB_KGB's Avatar
I had this issue with my Manley pistons, I changed it to CP and it worked fine.
Manley told me that my builder made a mistake with the pistons rings... Oh well...lesson learned
JasonEcks
Apr 15, 2017 07:32 AM
benIX
Dec 25, 2016 10:35 AM
FTONOOB
Jan 5, 2016 07:07 AM
BadassEvo8
Apr 22, 2015 09:56 PM
turboj
Aug 20, 2007 03:19 AM
