Installing stm clutchline.
Old Mar 13, 2011 | 06:50 AM
nytalonTSi's Avatar
I have a STM clutchline, about to install it but was wondering which bango fitting end goes to which?
The larger bango fitting to the clutch master and smaller fitting to the slave?
Also I noticed that the holes in the bango bolts don't line up with the holes in the fittings? Does it make a difference whether or not the holes line up? Like in a oil line it doesn't make a difference. Not sure with a clutchline.
Thanks!
Old Mar 13, 2011 | 09:12 AM
raiceboi697's Avatar
It doesnt matter about the holes as long as you use the washer and have them good and tight, test fit the fittings after you have bleed the system. I wanna say big bolt for master and smaller for the slave but I'm not 100% sure. Also you need to know that the evo uses don't use a gravity bleeding system, if you haven't done a evo system yet pm me and I'll dig up some photos as it's kinda weird to explain
Old Mar 13, 2011 | 09:50 AM
okevolutionVIII's Avatar
Thanks!
I installed mine with the larger fitting at the slave and everything fit great.
Old Mar 13, 2011 | 09:55 AM
Nastynine's Avatar
Old Mar 13, 2011 | 11:55 AM
nytalonTSi's Avatar
Yup after taking everything apart and looking I seen which side goes where. Currently having a problem with getting the line not to pinch coming from the master cylinder. Simple job, pita.
Thanks for the replies!
Old Mar 16, 2011 | 08:31 AM
did you ever get this figured out
Gleason at STM
Oct 3, 2024 04:21 PM
asu11
Nov 15, 2016 04:44 PM
fast3voviii
Oct 7, 2014 06:41 AM
meggs00
34
Dec 21, 2011 04:13 AM
jdparadee
Lancer Tranny/Drivetrain Tech
Apr 20, 2009 09:52 PM
