Boost guage reading too high?
Old Mar 16, 2011 | 10:06 PM
craig05evo's Avatar
I recently installed an autometer ultra-lite boost guage. I am on a stock turbo (TD05HR-16G6-10.5T) in my 05 evo. I am reading 30psi. I am just about positive everything is wired and plumbed correctly. Anyone know if autometer guages are any good?
Old Mar 17, 2011 | 12:52 AM
evo8john's Avatar
If it is a mechanical boost guage, when the car is off does it read "0"? Autometer guages are typically pretty good quality in my experience...
Old Mar 17, 2011 | 01:24 AM
javicracer's Avatar
i will log the car and see whats up! i hope your not runing that psi on pump gas.
Old Mar 17, 2011 | 12:33 PM
craig05evo's Avatar
It is a mechanical boost guage, however its reading 10 psi when the engine is "off" and at idle it sits at like 10ish as well. At full throttle it is at 30 PSI. I have a manual boost controller as well.
Old Mar 17, 2011 | 01:08 PM
mifesto's Avatar
at idle it should be reading vacuum in In. Hg. below 0. anything above the 0 is positive pressure or aka you are under boost. if you are reading 10psi at idle, then your gauge is defective.
Old Mar 17, 2011 | 01:11 PM
mdsevo06's Avatar
Needs recalibrating. Contact your supplier or the manufactuer directly, they might send you another.
Old Mar 17, 2011 | 01:46 PM
craig05evo's Avatar
thanks for the help, I figured somthing was wrong but just wasnt sure.
Old Mar 17, 2011 | 01:48 PM
SwishaSweet's Avatar
keep it in for a week and be frontin just to show off how much boost youre running ha ha
Old Mar 17, 2011 | 06:30 PM
javicracer's Avatar
lol
