Injector question (size/set up)
Old Mar 17, 2011 | 09:03 PM
guest49582's Avatar
06' Evo IX MR
Hey everyone, I need to know what injector size and brand would be the best (ID is out of the question, too expensive for this broke guy haha) for the set up below. Every tuner I talk to tells me something different, so I want to hear it from the community.
Mods: Stage 1
K&N Drop in filter
255 Walbro Fuel Pump
Buschur TBE
Gruppe-S Boost Solenoid
Cosworth M2 cams
Dual Tune e85/91
After this, I plan on installing a Buschur HTA3076 turbo kit and also running that set up using a dual tune e85/91. Which injectors will work well before and after the turbo kit upgrade? I plan on using the stock block until it wears to the point of need for replacement so horsepower range should be no higher than about 450whp with a 550 whp goal after a built motor is installed later, clutch and supporting mods are included but not listed. Thanks everyone!
Old Mar 17, 2011 | 09:47 PM
Bryant05TB's Avatar
https://www.evolutionm.net/forums/ev...-can-help.html
I'd go with FIC 1450's
-Bryant
Old Mar 17, 2011 | 09:51 PM
guest49582's Avatar
Originally Posted by Bryant05TB
Those are the BlueMax right? Do they just drop in or require any mods?
Old Mar 18, 2011 | 11:42 AM
guest49582's Avatar
Anyone? I need to get injectors asap. What do you guys recommend?
