code P0456/ Not idoling
Old Mar 23, 2011 | 04:19 PM
chasethorpe5126's Avatar
After about a hour highway drive, pulled off my exit and the car shut-off. The car startes if i give it gas, and runs fine when driving. just doesnt idol at a stop. my car has b.c 280 cams and tbe, it's untuned, but ive been driving like that for a year. i'm getting a p0456 code (evap system very small leak), and the rear o2 codes but i not running a cat. Can a p0456 cause idol probables? any ideas?
Old Mar 23, 2011 | 04:22 PM
sharkm87's Avatar
u check the hose behind the Intake mani?....
Old Mar 23, 2011 | 04:27 PM
The one that everone says to tap off of for the boost gauge? i just put a AEM tru boost on a like a week ago.
Old Mar 23, 2011 | 04:34 PM
sharkm87's Avatar
no..not that one... behind the intake... may have to remove the UICP to get to it...or you can try to feel around...but theres a cylindracle (spelling) valve...that thehose pops off all the time..for the evap system
Old Mar 23, 2011 | 04:44 PM
O Sweet, ill check that. do u know if that can cause a idol trouble? it's on the throtle body? Thanks man
Old Mar 23, 2011 | 04:47 PM
sharkm87's Avatar
any boost leak can cause adverse idle issues... no its not on the throttle body..its bolted to the actual intake manifold facing the firewall towards driver side.
Old Mar 24, 2011 | 05:14 AM
sharkm87's Avatar
ok there u go... found a pic from another user who posted..
thers the egr valve under the throttle body.... the vac lines always come off.. so check that
Old Mar 24, 2011 | 05:17 AM
Alexl08's Avatar
Idle
- 3 dictionary results
i·dle
   /ˈaɪdl/ Show Spelled [ahyd-l] Show IPA adjective, i·dler, i·dlest, verb i·dled, i·dling, noun
–adjective
1. not working or active; unemployed; doing nothing: idle workers.
2. not spent or filled with activity: idle hours.
3. not in use or operation; not kept busy: idle machinery.
4. habitually doing nothing or avoiding work; lazy.
5. of no real worth, importance, or significance: idle talk.
6. having no basis or reason; baseless; groundless: idle fears.
7. frivolous; vain: idle pleasures.
8. meaningless; senseless: idle threats.
9. futile; unavailing: idle rage. –verb (used without object)
10. to pass time doing nothing.
11. to move, loiter, or saunter aimlessly: to idle along the avenue.
12.(of a machine, engine, or mechanism) to operate at a low speed, disengaged from the load. –verb (used with object)
13. to pass (time) doing nothing (often followed by away ): to idle away the afternoon.
14. to cause (a person) to be idle: The strike idled many workers.
15. to cause (a machine, engine, or mechanism) to idle: I waited in the car while idling the engine. –noun
16. the state or quality of being idle.
17. the state of a machine, engine, or mechanism that is idling: a cold engine that stalls at idle.
Old Mar 24, 2011 | 05:20 AM
sharkm87's Avatar
Originally Posted by Alexl08
Idle
i·dle
–adjective
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
–noun
16.
17.
was this neccessary?
Old Mar 24, 2011 | 05:22 AM
Alexl08's Avatar
if you do not correct someone mistake then they continue to make the same mistake. Im bettering America buy this lol.
Old Mar 24, 2011 | 05:27 AM
sharkm87's Avatar
...carry on sir
Old Mar 24, 2011 | 07:31 AM
andrewzaragoza's Avatar
also for you, it should be "by" not "buy"
Old Mar 24, 2011 | 07:33 AM
Alexl08's Avatar
damn I look like an idiot now lol. It was also 8:22 am thats my excuse
Old Mar 25, 2011 | 04:53 PM
Srry 4 the spelling, i checked the hose's and they are all look fine. eveyone maybe knows something else, to check?
Old Mar 29, 2011 | 10:26 AM
dastallion951's Avatar
either your tune might be wacky, or double check your vacuum lines for tears in them, look at the pic above OP, to see if any of them are torn... or off
