Tial BOV not opening?
Old Mar 28, 2011 | 04:48 PM
Pirana's Avatar
Question Tial BOV not opening?
Well recently I've been having some stalling issues after a boosted run. Car will run perfect until the run...after that it wont stay in idle. I dont know what it can be but I've seen that the Tial BOV wont open when I rev the engine (without a load) unlike the videos posted on Tialsport.com. Thinking that maybe its getting stuck open after a hard run. I checked the vacuum source and it seems to be working perfect with a strong vacuum.
BTW, tried to email Tial, and all email accounts returned undeliverable.
Old Mar 28, 2011 | 06:06 PM
cfdfireman1's Avatar
clean it?
Old Mar 28, 2011 | 06:08 PM
Pirana's Avatar
I did. No change.
Old Mar 28, 2011 | 06:16 PM
camoevox's Avatar
my first rec would be to clean/possibly lube it but it may need new spring
Old Mar 28, 2011 | 09:11 PM
Pirana's Avatar
Ok i just lubed it. Has the "raw" colored spring. That sucker is extremely strong. I couldnt contact Tial to verify spring with the 280 cams.
Old Mar 29, 2011 | 10:46 AM
TiALSport's Avatar
with 280 cams you probably need the -6 or -8psi spring...did you recently do the cams?
Old Mar 29, 2011 | 10:55 AM
06MREvo's Avatar
What spring is in there? I was gonna say maybe the spring is too stiff....I have an 8psi spring for sale if you are interested...
Old Mar 29, 2011 | 10:56 AM
Pirana's Avatar
It has the raw color spring. Cams were changed last year. Same time with this BOV.
Old Mar 29, 2011 | 11:03 AM
MasterNater's Avatar
You need to find out how much vacuum the car pulls at idle, and choose the correct springs based upon that. The engine vacuum is what pulls the valve open. Are you using the original 50mm or the newer Q?
Old Mar 29, 2011 | 11:04 AM
Pirana's Avatar
Original. BOV is about a year old.
Old Mar 29, 2011 | 11:11 AM
5LEEPERISAH23I's Avatar
hmmm.. spring might be two tight, or it could be the ur not running rec bov if your still on the stock ECU
Old Mar 29, 2011 | 11:13 AM
06MREvo's Avatar
Hes on AEM...
Old Mar 29, 2011 | 11:24 AM
Ok. Well, the unpainted spring is for around -20 in/Hg. I doubt you are pulling that much vacuum at idle with 280 cams.
Tial 50mm Spring Chart
Old Mar 29, 2011 | 01:26 PM
Pirana's Avatar
YEs, Im on AEM...also I dont have an aftermarket boost gauge with vacuum. But reading the OEM metric it says 25cm/hg.
Old Mar 29, 2011 | 07:07 PM
Well, assuming the conversion is the same as if you were doing a length measurement, that should be about -10 in/Hg.
BTW - You can hook up a laptop to the AEM and use AEMPro to actually see what your MAP sensor is reading @ idle.
