Why my car suddenly "Knock" seriously?
Old Apr 9, 2011 | 09:39 AM
dastallion951's Avatar
personally an easy swap to see if its gas related, james try swapping to a different brand of gas....sometimes bad quality gas can cause knock due to bad additives in gas...what plugs you running and what gap?
Old Apr 9, 2011 | 11:17 AM
jameswwt's Avatar
Hi Dastallion, i truly agree as ive changed back Esso and it do help alot...
My plug gapped at 0.020
After my fine tune, everything is fine now...
Old Apr 9, 2011 | 04:33 PM
RSMike's Avatar
fine tune or reduction in timing?
i'm glad you've worked it out
Old Apr 9, 2011 | 11:23 PM
jameswwt's Avatar
Mike, im so glad that you are around whenever i need help...
I'll be putting in new BC valvesprings, retainers, GSC lifters and GT3076R turbo...
Hope everything will work out fine and if not, i need RSMike to the rescue...hahahaha
Old Apr 10, 2011 | 08:36 AM
your plug gap is at .020 man thats a really tight gap, try opening up your gap to .022 or .024 to close a gap can affect your performance...
Old Apr 10, 2011 | 09:47 AM
jameswwt's Avatar
Omg, i didnt know that! Will do that tmr...
Old Apr 10, 2011 | 11:52 AM
RSMike's Avatar
have you tested that i the dyno?
James i wouldn't worry about it.
As long as it's not missing
Old Apr 10, 2011 | 04:13 PM
no i dont currently own a dyno but its a proven fact, read this article: http://www.ehow.com/about_6072203_ga...-critical.html
Go to the section titled "Proper Spark Plug Gap" maybe it would teach you to second guess me. haha
but thats what i was taught in automotive trade school, too close of a gap will cause it too run rich since the af compressed mix wont ignite properly, too wide and it might not fire.
Old Apr 10, 2011 | 05:27 PM
jameswwt's Avatar
Thanks Guys as both gotta point...After gapped 0.02 my mis-fire gone.
Old Apr 11, 2011 | 08:38 AM
boom! your welcome, thatll be a couple beers thank you haha
Old Apr 11, 2011 | 08:57 AM
jameswwt's Avatar
If you are in my country than it will be a couple of Barrel for you Dastallion....hahahahaha
Old Apr 11, 2011 | 09:02 AM
95630706's Avatar
***Ninja edit***
OEM tech manual say .020-.024.
Old Apr 11, 2011 | 11:51 AM
RSMike's Avatar
BOOM lol
Old Apr 11, 2011 | 05:32 PM
thats good 956 guy, but its like torque specs, they dont have an exact number, but an around about torque, i usually start in the middle then double check...
Old Apr 13, 2011 | 07:12 AM
EvO_vIII_McCoY's Avatar
Sort of what happened to me, I took the spark plug out when i set it to top dead center when i boost leak checked it and i accidently hit the plug and messed up the gap lol.
