Best Turbo in T3 frame?
What is the best mid size turbo in the t3 frame? Wanting better spool.
I am currently playing with the idea just to replace my t3 5 bolt gt3076r for something better.
I know turbo technology has changed alot over the years, Im hoping there is a new turbo that will fit what I want.
The GTX3071R has caught my attention.
Currently I'm using a full race single scroll gt3076r .63 a/r kit. Running 23psi, it makes around 400-420whp.
I'm thinking maybe using the gtx3071r with my fullrace gear and maybe adding cams!
Someone wanting to make power/balance with stock 2.0 litr.
Looking at the compressor map, it should be able to go up to 54-56lbs/min which should be around 540-560whp.
Im wondering would a .82 or 1.02 be better. I'm going to have to use a higher psi to reach the same power as my GT3076R to achieve the same power I'm at now.
