short Shifter with a very tall selector?
I have no use of my right arm. I was in an accident and can't use it. I got the Evo VII because it's RHD, and I can shift with my left hand. I have to let go of the wheel to shift. So i'm trying to find a company that makes a very tall shifter, that's also a short shifter. I'm looking for something that's close to the steering wheel so I have less time with my had off the wheel. (keep in mind the car is RHD, so I can't use anything that is bent towards the left of the car to make the shifter closer to the driver) The only thing i've found is a TWM shifter with one of their 4" extenders. The problem with that is that I fear it won't be tall enough, and since it will have the extender piece on it, the throws might be long.
I'm not sure if anyone sells anything, or if i'm going to have to find someone to make a one-off piece. Thanks for any help.
For a shifter extension you might want to check here:
http://www.lathewerks.com/shop/
Just specify your needs and Chris will custom make it for you
As for the short shifter,Works sells a nice one.
We have both of the things your looking for
. If you pick up our EVO X short shifter for RHD cars and the 4inch shift extender, you'll get the reduced throws while bringing the shift knob much closer to the steering wheel. We can also do custom bends in the extender as well.
You can find the short shifter at this link:
http://www.twmperformance.com/shorts...rtshifters.htm
And the extender here:
http://www.twmperformance.com/shifte...ders/index.htm
If you have any questions or concerns, please let me know and I'll be happy to help!
Thanks,
Patrick
Team TWM Performance
. If you pick up our EVO X short shifter for RHD cars and the 4inch shift extender, you'll get the reduced throws while bringing the shift knob much closer to the steering wheel. We can also do custom bends in the extender as well. You can find the short shifter at this link:
Thanks,
Patrick
Thanks,
Patrick
Thanks,
Patrick
weap0n
May 17, 2012 02:54 AM
