CBRD- more custom...well... stuff ;)
We are doing a nice build for our long time friend and client George-
He came to us about 6 months after we opened after another shop led him off the proper path and we have since worked close with him to make sure his evo is what he needs for his track use!
The car was originally one of our BBK beta test cars, then a BBK-B test car.... and now will be running a custom entire setup....
CBRD Dual pass Radiator (same one we built for evodan but different inlet/outlets)....
CBRD Custom Garrett Core FMIC with hargett quick disconnects..
CBRD Custom IC pipes
CBRD 2L Road Race motor
CBRD Rod Race cylinder head with inconvel valves etc---(unless the EFR 7670 shows up in time)
CBRD Custom Manifold with CBRD 33RB-2 turbo in Tial housing
CBRD Custom Air intake with stock MAF
Turbosmart 45mm WG
and some other bits--
The car is also getting a custom power steering cooler, Shep built rear dif, and RacePaq dash with GPS and Data ...
Car already has Motons.... Big Stoptechs, 18x10.5 wheels with Advan tires- etc..
I will be posting pics as the build proceeds
Here is something to get us started....
Cheers
CB
Turbosmart 45mm WG
Cheers
CB
pretty sure I know who's car this is... and I can't wait to see it out on track.
Looks awesome and I'm sure its going to drive even better than it looks.
when are you guys going to be done?
Looks awesome and I'm sure its going to drive even better than it looks.when are you guys going to be done?
shes under the knife right now-
modified upper and lower radiator support to mount the intercooler and radiator-
both ic pipes going straight out the back, and ducting to channel air-
Waiting on the 7670 EFR-
cb
cb
