chatter
Old May 4, 2011 | 11:49 AM
boczo777's Avatar
chatter
2003 evo 8, put MT-90 in trans, heavy shockproof in transfer case and rear diff
when on full wheels lock the car chatters, i just got redline friction modifier
just wanna double check where to add it and how much
i think evo 8 doesn't have central LSD right??? only in rear diff got it right???
Old May 4, 2011 | 01:25 PM
barneyb's Avatar
The center diff is limited slip but does not require additive.
Old May 4, 2011 | 01:29 PM
boczo777's Avatar
so just add little to rear one and i should be good??
Old May 4, 2011 | 01:41 PM
barneyb's Avatar
I've always used diaqueen so I've never had this problem with my Evo.
The rear differential is a clutch type and it can chatter if you don't use the correct lubricant/additive. You should only notice this when turning. Since I haven't encountered this problem I can't know how much of the additive to use.
Old May 5, 2011 | 05:57 AM
boczo777's Avatar
bump, anybody??
Old May 6, 2011 | 04:55 AM
boczo777's Avatar
bump
Old May 6, 2011 | 07:43 PM
barneyb's Avatar
How much additive to use? Use a little. If that doesn't solve the problem, use more.
EvaTheEvo
Feb 6, 2016 07:04 PM
OldManQuentin
Apr 14, 2014 07:05 PM
nukleus
19
Jul 17, 2013 06:18 AM
omniprobe
Aug 22, 2011 05:06 PM
CBRE
76
Jun 22, 2011 07:21 AM
