Not much POWER gain after tune???
Let me guess, is the car sounding like its producing a lot of boost but not move like it sounds...
James, My friend had an evo 8 with thr profec and experienced the same thing. He replaced a part in the boost controller system and it fixed it. I will try to find out what it was and try to get back to you.
is the e-boost controller new? or used?
Will truly appreciate if you could help me...
Thanks
1. greddy profec b spec II is a very good ebc, I've used it for so many year before I switch to ecu boost control.
2. 3076R is a slow response turbo, why would you even go with that turbo? never heard of bigger turbo has turbo lag? I bet a stock 9 turbo with bolt on can walk your setup. you should've look into a hks 7460R or bbk
There are lots of thing to consider ...
How big is the exhaust housing 0.63,0.82 or even 1.06 ...
What is your engine 2.0,2.1,2.2,2.3 or even 2.4L ..
How much boost are you running ...
What type of fuel are you using ...
In Malaysia .. we only have ron97(highest ron) & we usually don't run boost over 2bar ...
We also don't use meth or E85 which is better for turbo cars ...
Here a gt3076r new is about rm4000 while a HKS 7460r will cost an arm & a leg ..
If you and your tuner have checked out the lines for your controller and they are fine then I am not sure.
Are your running on 3 cyclinders! not to be funny... it really sounds like a bad turbo then. did u buy the turbo new or used. compressor wheel is bad????maybe
Other than that i dun think thats the problem...
Thanks for sharing
