boost controler issue
I recently swaped from a jam nut style brass boost controler to a hallman both manual controlers i was tunes at 28 so in process of dialing in hallman but for some reason i can't get over 20 psi with it for some reason
Is the flow going in the right direction through the boost controller? And also make sure that you're doing the pull in 3rd or 4th (i know thats not what it is, but want to make sure that's what you're doing)
i believe so i set it up same as brass boost controler was the side outlet going down towards turbo and other line coming into back side or fitting inline with the knob i didnt have instructions so just put it on same as exsisting one
i am leaning towards the spring but here is best link to pics i can find http://www.hallmanboostcontroller.com/howto.html i am using a different boost line from older controler but the B line is surely going to the wastegate actuator i swapped old one on for now and will test it later i guess i have to find a way to get the stiffer spring
Yeah, you are good to go. If you are unable to boost over 20# then you could try increasing wastegate spring pressure by rotating the turnbuckle on the end of the threaded actuator rod.
