using stock valves on a built head!?
Old May 14, 2011 | 04:56 PM
03evilution's Avatar
From: Poughkeepsie NY, Central Jersey Shore, Fort Meade MD
i was recently owned by a shop building my motor and selling me a bad head...i now have to use my stock head and was going to just change out the dual springs and retainers to my stock head. i was thinking about getting a set of ferrea 6000 series but i believe i would have to change out my valve guides and well im trying to keep machine and part costs to a minimum but at the same time do the job right the first time to not have additional failures down the road. i have a fully built block and will be running hks 280 cams and using a pte6262 turbo. can anyone give me some insight. can i use the stock valves or am i just asking for failure and does anyone know if u can use the stock valve guides with a set of ferrea 6000's.
Old May 14, 2011 | 05:12 PM
boostless's Avatar
stock valves are fine unless ported for a larger valve, obviously. Tune will suffer though
Old May 14, 2011 | 09:53 PM
why do you say the tune will suffer?
Old May 15, 2011 | 02:49 AM
STi*guy.kiev's Avatar
you'll have benefits going to either ferrea 6000 or MAP stock size valves, but a cleanup / performance valve job will do much more. I would do ceramics before upgrading valves.
Im getting some titanium ones built in 0.5mm oversize...
Old May 15, 2011 | 05:43 AM
mrboost05's Avatar
i dont believe stock valves take to the heat as well as aftermarket ones y dont you give headgames a call tommorow and get a opinion from them while you are on the phone get a quote.
Old May 15, 2011 | 06:27 AM
ok thanks guys...im gonna get a set of ferrea 6000's and a valve job done
evolvedevo91
28
Sep 15, 2015 05:08 AM
klever
10
Oct 13, 2014 07:03 PM
Headgames Motorworks
Feb 11, 2014 01:13 PM
tsidrift1
23
Nov 9, 2013 06:10 AM
2006GSR
Oct 16, 2013 04:56 AM
