Timing Belt Movement - Normal?
Old May 14, 2011 | 06:44 PM
C3L1CA's Avatar
Is it normal to have a little movement on the timing belt between the intake cam and the tensioner pulley when revving the motor?
It almost ripples for a split second like a motorcycle chain when revving it, then goes back to normal while keeping a steady rpm, then ripples again before going back to normal when idling. It doesn't move a lot but enough to make me a nervous.
Does any other evo have the same thing? Am I being over paranoid?
Also if it matters I have a gates racing timing belt. It also seems to have normal tension between the two cam gears and between the tensioner pulley and intake came.
Thanks guys!
Old May 15, 2011 | 01:45 AM
My03evo's Avatar
Honestly I'm not sure but if I was too guess I would say it's on the loose side. and I see alot of people do not how to set the timing belt the RIGHT WAY....I have seen some adjust it perfect so the grenade pin goes in and out smoothly then buttoned it up, but you have to spin the engine over and wait like 10 mins to give the hydraulic tensioner to adjust. It has taken me a while to get the hang of it the first time to get it perfect but I'm also a perfectionist. If you dont do this then the belt WILL be too loose once the tensioner adjusts itself and can risk your valves smacking the pistons. Maybe not in your case but in general if it was too loose
The scary part is I see this bad way being done by "pros" and I just started with these engines and I know how to do it more properly than them....Another reason why I have no faith in people these days, and why I do all the work myself
But from what I remember I dont remember seeing ripples on my belt but not positive on that
Old May 15, 2011 | 09:12 AM
C3L1CA's Avatar
I set the timing by getting the grenade pin perfect, turn motor over until timing marks line up, let set for a while, then it was still perfect. I did this a couple times just to be sure.
Anybody else have the same issue? Or is it normal?
Old Jun 17, 2011 | 03:30 PM
C3L1CA's Avatar
[youtube]UdrZAg5Jb08&hd=1[/youtube]
Just pulled the top timing cover and seem like there was more movement than before.
Should I be worried?
Old Jun 17, 2011 | 03:39 PM
meckert's Avatar
so how much deflection do you see from the belt when you try and push on it between the sprockets?--- shouldn't have any, belt should be firm. If your seeing the scrockets move or your getting the belt to press down...its too loose.
Old Jun 17, 2011 | 04:02 PM
TommiM's Avatar
sort of off topic, but how much deflection should the balance belt have? Should it be as tight as the timing belt or almost be loose to the point where it looks like you can slide it off?
Old Jun 17, 2011 | 04:05 PM
RazorLab's Avatar
It has more slack at one point of revolution then the other. I can't remember if its TDC or opposite.
Old Jun 18, 2011 | 12:27 AM
nightwalker's Avatar
That's normal. Too tight and you'll have other problems in the future, especially with that type of belt.
Old Jun 18, 2011 | 08:08 AM
guest49582's Avatar
Tensioner
Old Jun 18, 2011 | 09:14 AM
barneyb's Avatar
When I did my 60K I used a new tensioner and let the adjustment sit over night. When it was still okay in the morning I buttoned her up and never looked at the running belt. I mean, when the tensioner is good, and the tension is set correctly what else is there to do?
Old Jun 18, 2011 | 09:39 AM
MasterNater's Avatar
The belt is tighter at TDC.
Old Jun 18, 2011 | 02:11 PM
fast3voviii's Avatar
be carefull about having those ****ty kevlar belts too tight. ive had one snap and ruin everything on my old motor because it was overly tensioned
Old Jun 18, 2011 | 03:19 PM
acssa's Avatar
mine is also like that... i thing its better that way.... dont want to much tension between the cams. I also checked that the gears were 100% on the marks and the belt had the play like that. I used a Cosworth belt.
Old Jun 18, 2011 | 03:37 PM
mirebih's Avatar
i might have the same problem, and I was gonna post the question about it, but I'll just read the future posts.
BTW do you hear "rattling" noise after 4k rpm? Mine almost sound like catalytic cover is loose and its rattling, but I dont have a cat nor any covers.
anthonypazsd
135
Apr 2, 2026 12:56 PM
heavens turbo
Aug 3, 2016 10:02 AM
Hotsauce101
Apr 6, 2016 06:27 PM
awd2gen
12
Jan 2, 2010 02:59 PM
troe666
11
Sep 4, 2006 07:37 PM
