I need help
Old Jun 5, 2011 | 10:06 AM
Richysevo9's Avatar
I need help
just got a evo8 and it push 20psi. For some reason it breakup at 18 to 20.it ****ing moves just fine at 17
Some poeple telling me it drying up is this true or not
Old Jun 5, 2011 | 10:20 AM
BluEVOIX's Avatar
What do you mean by "it drying up" ?
Well if your having break up issues, start with checking the simple things.
-Inspect spark plugs are for an Evo 8 head.
-Make sure its not some cheap brand.
-Make sure they are not fouled
-Double check gap is within correct range for your application (.022 to .024 for your boost level)
Research on which spark plugs are recommended for Evo 8. If all is correct then its probably your coils going out.
Old Jun 5, 2011 | 10:23 AM
crewdawg130's Avatar
+2.. plugs
Old Jun 5, 2011 | 10:55 AM
nightwalker's Avatar
Was it tuned before you got it? Is there a manual boost controller on it? There are a lot of things than can cause your problem. Also check the spark plugs like the guys suggested.
Old Jun 5, 2011 | 11:23 AM
javicracer's Avatar
"it drying up" ?
Old Jun 5, 2011 | 11:32 AM
PsychDr. HN$'s Avatar
Plugs
