Safe to run two boost gauges?
Old Dec 26, 2003 | 07:02 AM
MYEVO8U's Avatar
I already have digital boost gauge hooked up now, but my local dealer is offering me a good deal on the sport meter kit. Can I have two boost gauges hooked up at the same time? Has any one tried this before?
Old Dec 26, 2003 | 07:27 AM
Quickshift's Avatar
Ya it is no problem tapping into the boost line twice. I have a boost controller and boost gauge running of the fuel regulator line and had -0 problems.
Old Dec 26, 2003 | 07:50 AM
MalibuJack's Avatar
Yah, its not really a problem.. The only issue may be that if you have several things tapped into the same line, the gauge or sensor readings might be off slightly.. but I wouldn't worry if its just gauges.
Old Dec 26, 2003 | 08:29 AM
zlancer's Avatar
well you do have to be carefull...if you tap off the same like with a T fitting you might actually have a significantly larger difference since the rush of air blowing over the T fitting might make a vaccuum for one of the guages....i would seperatly hook up the boost guage and digital boost guage to different sources.
Old Dec 26, 2003 | 10:23 AM
MYEVO8U's Avatar
Thanks for your help guys.
What other sources can I use besides the VAC line coming from the Intake Manifold to the BOV?
Old Dec 26, 2003 | 10:39 AM
SilverEvo8owner's Avatar
the line that goes to the BOV
MurtazaDSM
Feb 16, 2017 05:42 PM
ahr4156
May 29, 2012 03:36 PM
bwanner
Jan 13, 2012 01:01 PM
hkfeet
Jan 23, 2005 07:19 PM
avengerhed
Sep 27, 2004 02:38 PM
