bov opinions over 450whp?
Old Jul 14, 2011 | 08:38 AM
PlanoEvo's Avatar
Looking for opinions on bov options for cars in 450-550whp range what are you using?
Old Jul 14, 2011 | 08:40 AM
escodotcarter's Avatar
depends on how much boost you are running but I would guess any aftermarket bov would suffice.
Evo Tengoku's Avatar
Tial ?
Old Jul 14, 2011 | 08:45 AM
PlanoEvo's Avatar
30-35# on E85
Old Jul 14, 2011 | 08:48 AM
2004EvoVIII's Avatar
Ron at RS Motors here in MN has just over 400 on his 9 and he has a completely stock motor, FMIC, turbo and BOV. I personally plan on getting mine into the 380-420 range and will use a 9 turbo and 9 BOV w/E85 and 1000cc injectors. The stock 9 BOV's are made VERY well
Old Jul 14, 2011 | 09:12 AM
Kracka's Avatar
His crushed IX is leaking. I've suggested the Cobb BPV and Synapse DV. He will need something that's compact and fits it the stock location (VTA is not an option, he is still running MAF).
Old Jul 14, 2011 | 09:15 AM
RockmanX's Avatar
get a aps twin vent bov. problem solved and fits stock location Hey op are you in plano tx??
Old Jul 14, 2011 | 09:17 AM
BenJ's Avatar
Only two bov's that are worth anything are the stock 9 or tial. Keep in mind one thing though. The stock 9 bov will taper pretty badly and will only hold about 21-28 psi by redline depending on whether or not it has been crushed. The Tial is the only bov that I will run.
Old Jul 14, 2011 | 09:21 AM
PlanoEvo's Avatar
Deleted
Old Jul 14, 2011 | 09:24 AM
PlanoEvo's Avatar
Where they stopped making them and used as hard to find. No I'm in IL
Old Jul 14, 2011 | 09:26 AM
RockmanX's Avatar
Originally Posted by PlanoEvo
Where they stopped. Making them and used as hard to find. No I'm in IL
im telling you get a used one off the forums i know of a 750+whp evo using aps to perfection and im 600whp no issues. you can get them used for like 100-200 range. Wow was not aware they stopped making them lol glad i got mine when i did over a year ago. Pick one up and you will be good to go for over 40psi if you so desired.
Old Jul 14, 2011 | 09:29 AM
Kracka's Avatar
No I'm in IL
Tin foil hat?
Old Jul 14, 2011 | 09:41 AM
raasfaas's Avatar
500+hp here and my Synapse is holding perfectly...I'm running the new DV.
Previously I had on a dejon tools modded stock DV, and just switching bov's (nothing else changed) I held +2psi from peak all the way to the tail.
Old Jul 14, 2011 | 09:45 AM
Paintballguy's Avatar
synapse dv or aps twin vent if you can find one
Old Jul 14, 2011 | 01:57 PM
red03evo's Avatar
tial 50mm for me
