So i pulled my ayc diff out today out of my Tme Evo 6
Old Aug 1, 2011 | 02:57 AM
Huckin's Avatar
Can someone enlighten me in what i have found? is the diff center in the photo a cusco/ aftermarket item (reason i say cusco is i have a cusco front diff too)
the car was a little clunky when powering on & off thru corners, if someones had an issue like this before where should i start looking, every thing appears to be fine however i'm no expert on diffs..
Cheers
Attached Thumbnails So i pulled my ayc diff out today out of my Tme Evo 6-photo-5.jpg   So i pulled my ayc diff out today out of my Tme Evo 6-photo-2.jpg   So i pulled my ayc diff out today out of my Tme Evo 6-photo-1.jpg
Old Aug 2, 2011 | 06:39 AM
rawkus's Avatar
The differential is absolutely not an OEM AYC or SAYC differential. I would guess it to be Cusco, but I haven't personally seen one up close. Why did you remove the AYC clutch assembly?
Dan
Old Aug 2, 2011 | 07:16 AM
Piro Fyre's Avatar
Yes sir, that looks to be Cusco. The plate groove design seems to be the same.
Attached Thumbnails So i pulled my ayc diff out today out of my Tme Evo 6-plates.jpg
Old Aug 3, 2011 | 12:30 AM
Huckin's Avatar
Had a noise in the rear, and decided to inspect.. all the ayc gear is now removed, and diff is back together. i dont think the diff was the problem but the ayc gear is redundant with the lsd anyway/
I left the ayc housing in, but removed all the gears and plates from it, so its really just the lsd, shaft and housing left.
i think the noise is from the old bushes on the diff mounts..
Dallas J
Sep 10, 2019 11:45 AM
Segfault
Evo X How Tos / Installations
26
Oct 23, 2018 09:43 AM
psycko069
Jul 8, 2015 06:08 AM
rupp003
33
Aug 29, 2013 10:26 AM
maximusnz
Sep 28, 2009 05:52 PM
