AMS RACE FUEL RAIL INSTALLn
Old Sep 18, 2011 | 07:45 PM
evoballer's Avatar
I’m going to be installing my New AMS Race Fuel Rail Tonight and I’m going to be doing -8 Fuel lines. But I’m going to be doing a temporary setup by expanding the Fuel Feed Line from the stock -6 to -8, so I will be able to use this AMS Fuel Rail with the same size fuel line I plan to run with my big turbo setup. I’m also going to be reducing the Fuel Return Line from the AMS Fuel Rail mounted -8, to the stock return hard line that is a -4. I plan on doing this by the use of 2 female AN fittings and 2 male Reducing a fittings to reduce from -8 to -4. This will only be temporary set up until I can run a -8 line from my Buschur Double pumper in my fuel tank. I was also thinking about using the stock -6 fuel feed hard line as the fuel return line Since I will be running the -8 From the tank. Does any one know if this will work? I am just looking for input because I want to install the Fuel Rail because im going to be putting a 65mm "TB" and JDM intake manifold in at the same time.
ANY HELP OR SUGGESTIONS WOULD BE GREATLY APRECIATED!!!!!
Old Sep 18, 2011 | 10:41 PM
evoballer's Avatar
Help!
DOES ANYONE KNOW IF THIS TEMPORARY SET-UP WILL WORK
Old Sep 19, 2011 | 05:54 AM
Scottr126's Avatar
With enough fittings anything can work. However though I would recommend waiting until you get your -8 lines in to install the rail to save yourself the trouble?
Old Sep 19, 2011 | 09:28 AM
longdingydong's Avatar
how long are your fuel lines? gettin ready to switch mine over to an, but was looking for the amount of length i will need for the feed and return. any info appreciated
Old Sep 19, 2011 | 12:29 PM
evoballer's Avatar
i went ahead and bought 6 ft just to be safe but i think u could get by with 4 or 5 and that is just to the stock hard lines from the tank im not quite sure my friend ran -10 on his evo 8 from the tank i will as him how much line he used.
Old Sep 19, 2011 | 07:25 PM
please do. u can pm me if you find out
Old Sep 20, 2011 | 12:43 AM
evoballer's Avatar
ill find out tomorrow and ill PM you
