Evo 9 GSR Oil/fluid Change
Old Sep 25, 2011 | 12:26 PM
TommiM's Avatar
Originally Posted by llDemonll
I'm guessing you run this, if so how did it feel compared to OEM?
Have you tried the "cocktail" mix at all from redline?
I am using the redline "cocktail" mix. After having tried quite a few different fluids actually, I found the redline cocktail mix to be the best,imo (evo 8 speed).
Old Sep 25, 2011 | 03:28 PM
hatakashi's Avatar
This sounds gooooooooood!!
How much does the gearbox need?
Old Sep 25, 2011 | 03:43 PM
Raptord's Avatar
2 quarts of MT90 and 1 quart of MTL
(1 quart roughly equals 1 liter)
Old Sep 25, 2011 | 05:27 PM
hatakashi's Avatar
So it means the gearbox itself holds around 3 litres of oil ... I think I'll go for Redline too.
Old Sep 25, 2011 | 06:02 PM
TXEvo8chris's Avatar
I just picked up my 05 Evo8 MR edition yesterday... I want to do a complete flush/fill aswell.. Can we be more specific with the 6speed oils.. This thread is a bit confusing..
Old Sep 25, 2011 | 06:49 PM
hatakashi's Avatar
For 5-speed, the oil type recommended is GL-3 or GL-4
For 6-speed, it's GL-4
Old Sep 25, 2011 | 11:51 PM
Thank you... Just placed my order
Old Sep 26, 2011 | 01:45 AM
hatakashi's Avatar
Envy you man...that you can order stuff just like that...haha
Old Sep 27, 2011 | 09:48 AM
Old Sep 28, 2011 | 03:05 PM
hatakashi's Avatar
I am having extreme difficulties in sourcing GL-4 soil for my tranny...
I can't even find Redline equiv in HK...
Old Sep 28, 2011 | 08:44 PM
hatakashi's Avatar
A question...would Toyota's GL-4 fit my Evo 9 GSR 6-speed tranny?
Old Sep 29, 2011 | 10:08 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
You can try it, your transmission won't explode or anything since it's a similar formula.
See how it feels after a few miles and if there are no issues with shifting and it feels okay when cold and hot, you're probably fine.
Old Sep 30, 2011 | 06:45 PM
hatakashi's Avatar
Finally I've sourced all oils...
For tranny oil, reluctantly I have to use Redline MT-85 as Diaqueen GL-4 is 100% not avabilable in HK and most on-line shops don't ship to HK...
I'll see what Redline feels like and decide my next move
Old Oct 3, 2011 | 01:25 AM
hatakashi's Avatar
A big question...please help
Since my E9 GSR is Jap spec with AYC...therefore I need to change the AYC oil.
I know the front diff uses LSD oil, what about the rear diff? Does it use AYC oil or LSD oil?
Old Oct 3, 2011 | 01:30 AM
riceball777's Avatar
i have always used
Transfercase and rear diff: Mitsubishi OEM GL5 LSD Gear Oil Diaqueen (Part #3775610)
engine oil i use mobile 1 10-30
5 speed transmission = 2 quarts of redline mt90 1 quart of mtl
