Need HELP ASAP with Full Blown System! Step Inside
Old Sep 23, 2011 | 08:19 PM
Anarchy99's Avatar
So obviously someone at Full Blown couldnt take the extra few minutes to get all of the fittings proper for the double pump before they shipped it. The pick below shows the empty hold where I need the proper size fitting. Anyone with the double pumper know the size? I will try ACE hardware tomorrow to see if they might have it but any help appreciated!
Old Sep 23, 2011 | 11:32 PM
boosted2x2's Avatar
The hanger does not come with that fitting so you can choose the size -an fitting and line you want to run. If you want to use the stock lines in the car full blown sells the kit to connect to it separately.
Old Sep 24, 2011 | 05:42 AM
Anarchy99's Avatar
That's the option I have is to run with OEM lines so it should have the fitting. The one that came is too small.
