2.0 Longrod Build Compression Issues
Old Oct 5, 2011 | 01:36 PM
pistonless's Avatar
Hi Guys,
I have built a 2.0 Longrod which consists of the following parts.
1. 156mm Howards Rods
2. Wiseco 2.3 Stroker Pistons
3. Cosworth 1.3mm Head Gasket
4. Ported Head with S90 Throttle Body
5. ATP GTX3582R
This issue is that the car is built and we had the car on the dyno mapping with SD. As much timing as we ran with no det the car made 530HP at the flywheel. Certainly not what we were expecting.
This is the first time a longrod was built which seems to be compression issues and there 2 factors which seem to be the issue.
1. To thick head gasket used
2. The block was not decked.
I have used a calculator to show you guys what compression i am most likely making.
http://rbid.ru/cr/?action=CalculateC...1997:0.3&print
I have 2 added options which i can think off without removing the entire engine and decking the block.
Option A : Use a thinner 0.8mm head gasket which will be 0.5mm less.
Option B : Deck the head about 0.3mm less
By doing this i can get a better compression rate although the stock 9 engine is 8.8
Does any expert engine builders know what are the squish characteristics and whats the best way forward?
Old Oct 5, 2011 | 02:00 PM
bostonhatcher's Avatar
I bet you accidentally put 150 mm rods on pistons calling for 156 mm rods. If so your piston is falling 6mm short of the deck.
Old Oct 5, 2011 | 02:07 PM
pistonless's Avatar
Defo 156mm I beam Howards Rods
Old Oct 5, 2011 | 02:28 PM
n2oiroc's Avatar
what was the exact part# of the piston you used? are you sure they are -21cc's? if they are, a thinner gasket wont help much. its just too much dish volume.
Old Oct 5, 2011 | 02:32 PM
pistonless's Avatar
The part number on the pistons are K596M855
Old Oct 5, 2011 | 02:36 PM
JohnBradley's Avatar
We normally run the pistons between 0.010-0.002 and run a .051 gasket for a squish of 1.4-1.5mm.
If you deck the head and go to a thinner gasket thats only going to give 8.2:1 which is still fairly low. If you are on pumpgas you can run more boost and timing than you could but it will most likely be a little less responsive.
The best option is obviously to get some custom LR2.0 pistons done in the compression ratio you want.
Aaron
Old Oct 5, 2011 | 02:40 PM
3gEclipseTurbo's Avatar
Im gonna say its the small turbo not just compression thats your problem.
Edit, I didnt look at your link. I had just saw your refferance to the stock 8.8, so i thought you were around that.
Old Oct 5, 2011 | 02:44 PM
How much was this amount of timing?
Old Oct 5, 2011 | 02:45 PM
RSMike's Avatar
that turbo will make 700whp easy.
Old Oct 5, 2011 | 02:47 PM
n2oiroc's Avatar
yeah, -21cc's. hate to be the bearer of bad news, but it looks like you need to swap pistons.
Old Oct 5, 2011 | 02:49 PM
pistonless's Avatar
Thanks Aaron..............what piston do you recommend I get? Anything of the shelf or custom made wisecos?
Also which head gasket is 0.51 thick? Make or part number please?
Aaron
Old Oct 5, 2011 | 02:57 PM
pistonless's Avatar
I will get the details from the mapper and th SD graphs posted tomorrow......she just refused to make more then flywheel 530HP.
Old Oct 5, 2011 | 03:05 PM
RSMike's Avatar
how much boost?
Old Oct 5, 2011 | 03:16 PM
pistonless's Avatar
Originally Posted by RSMike
how much boost?
2 bar boost which equates to 29psi ...........i know you guys hate our unit values
Just to add more the car was running on 98 octane level and its an evo ix.
Old Oct 5, 2011 | 03:40 PM
ta ace's Avatar
I have had good luck of using the custom manley pistons in both 2.0 LR and 2.4 LR however i have also heard good about wiseco hd series
