New DBB FP Green Installed and Initial Tune
Old Oct 21, 2011 | 01:34 AM
wrx2evoIX's Avatar
New DBB FP Green on EVO IX and Tune Progress
Completed my install of a new DBB Green last night and completed some basic tuning today. Thanks again to Mikey at Spec-Ops for his great service is supplying the turbo and to FP for making such nice products.
On the old IX stock turbo I was seeing an average of 340hp and 320lbft using Virtual Dyno 1.1.4 and Dynojet setting. With the Green I'm already seeing 380hp and 320 lbft at the same peak boost level of around 24 - 25 PSI and 390 - 400hp and 330lbft at 27 PSI tapering to 26 PSI at redline. Thing is the Green holds clean, cool boost all the way up top as well. This is on 93 octane (98 RON in Australia)
I'm slowly increasing the boost and trimming up fuel and WGDC and see where I get to.
The Green is making nice boost from 2500 RPM and in 4th gear hits 25 PSI at 3500 rpm, compared to the stock IX turbo which hit that around 3400 rpm.
My Car Setup
Motorsport Logic exhaust 3" dump back with high flow cat
Walbro in-tank pump
FIC 1100 injectors
Grimspeed 3 port BCS
Tomei Fuel Pressure reg
Excedy HD single plate clutch
FP Green DBB, ported with 18 PSI actuator
FP Inlet pipe
Tephra V7 with my tune
Everything else is stock
Best I did on the old IX turbo was a 12.43 quarter mile at 111 mph (93 octane, 98 RON Australian). Cars done 58,000 miles and is my daily drive.
I chose the DBB Green for driveability, better top end than stock and reliability, ticks all boxes for me so far.
The sound of the DBB Green on song is something else
Latest tune on E85 (Eflex ranges from E70 - E85 in Brisbane, Australia)
Old Oct 21, 2011 | 05:29 AM
fqjdmct9a's Avatar
how did you get your hands on a DBB green?
Old Oct 21, 2011 | 07:07 PM
Mikey@Spec-Ops's Avatar
He got it from me Would you like one sir?
Gavin, thanks again for the great review. Have fun tuning it and turn the boost up and have fun. I'm glad you are loving your new turbo
Mikey
Old Oct 21, 2011 | 07:08 PM
wrx2evoIX's Avatar
Got in early, paid the money and waited. Mikey at Spec-Ops seems to have a good relationship with FP as well
Old Oct 21, 2011 | 07:16 PM
apagan01's Avatar
sweet deal, nice spoolup on that dbb,,, you couldn't have better help from the guys at Spec Ops,,, specially Mickey hes is pretty crazy but gheeky !!
Old Oct 21, 2011 | 07:31 PM
I do in deed
Really? I am pretty crazy and geeky...? I don't look geeky....
Old Oct 21, 2011 | 07:56 PM
sparky's Avatar
.....I'm slowly increasing the boost and trimming up fuel and WGDC....The Green...... hits.... peak (via the boost gauge) at about 3900 rpm, compared to the stock IX turbo which hit the peak around 3400....
What wastegate actuator is fitted to your Green? Peaking @ 24# by 3900 is way lethargic for a BB Green, IMO. If you can't get it to peak before 3400-3500 then I'd dowse it in petrol and throw a lit match at it. A 3900 RPM peak boost level is simply nothing to write home about.
Increase wastegate preload! You did state that you are slowly increasing boost and WGDC. So, there is still a glimmer of hope.
Old Oct 21, 2011 | 08:06 PM
Blue91lx's Avatar
@Mikey
What does the DBB Green cost and what HP level can it support? My 35r is getting tired and with all of these stock frame turbos make the same power with quick spool up, I think it may be time to make the switch soon!
Old Oct 21, 2011 | 08:09 PM
sparky's Avatar
I am not trying to be a *****(it just comes naturally)! But, to give you an idea, my journal bearing Red on a stock 2-Liter motor spools to 24# by 3400 RPM. Like I said it is journal bearing and in addition, being a Red, it is configured with a higher mass/inertia rotating assembly than your Green is.
Of course, I pretty much chopped most of the threads off the end of the actuator rod and run it without a backup nut so that the turnbuckle doesn't leave any threads showing whatsoever. Also it has a shorter length turnbuckle than what FP supplied it with.
It surges like hell though. I figure that the overall length of the actuator rod is about one inch shorter than a stock FP 18# WGA. It is so tight that I had to mount the turnbuckle hole onto the flapper valve's pivot arm with the WGA's bracket unbolted from the compressor housing and only afterwards did I bolt the actuator bracket to the housing.
Old Oct 21, 2011 | 08:13 PM
sparky's Avatar
Originally Posted by Blue91lx
.....What does the DBB Green cost and what HP level can it support? My 35r is getting tired and with all of these stock frame turbos make the same power with quick spool up, I think it may be time to make the switch soon!
You'll be giving up a lot of horsepower by downgrading from a 35R to a Green. A lot of peeps are doing just that though and loving the increased driving pleasure.
Old Oct 21, 2011 | 08:47 PM
Blue91lx's Avatar
I think I'm mainly after a quicker spool. I suppose a DBB Red would be ideal. However, I'm not even pushing my motor too hard with the 35r. It only did 450 on a Mustang Dyno, so that's really all I'd be after, as the car is my DD.
Old Oct 21, 2011 | 09:06 PM
sparky's Avatar
Blue91lx: Have you thought of an HTA 3076, or even a GTX 3076R instead of a 16G derivative. Wouldn't both of these turbos allow you to keep your present header and DP, etc.?
That is a nice engine build, BTW. Is your car running on E85? As you mentioned, an 84mm BB Red sounds intriguing with your combo though, EMS and all.
Old Oct 21, 2011 | 09:51 PM
Blue91lx's Avatar
Thanks man! I'm in the middle of changing to S2's, a Nisei IC, SpoolinUp COP and a re-tune as we speak. The 450whp was with an XS Power FMIC and BC 272 cams. Unfortunately, E85 is not available in the Philadelphia area . I have thought about doing a 3076 as I would like to keep the Shearer . However, the stock frame like the Red will offer much better spool from what I've seen and has the ability to make more power than the 3076! I agree though, it would be very nice to keep my custom IC piping, custom dump tube, Shearer manifold, etc. Honestly, I'll probably be a man, get used to the lag, and get the 35r HTA'd when summer rolls around.
Old Oct 21, 2011 | 11:26 PM
wrx2evoIX's Avatar
18 PSI WGA. 4th gear test I just did I recorded 26PSI at 3500. Also my Green is ported, which I understand will slow spool by about 100 rpm but helps up top?
Old Oct 22, 2011 | 02:41 AM
RSMike's Avatar
how the hell do you get a FP Red spooling to 24psi @ 3400rpm on a 2.0?
My 2.3 with Mivec makes 24psi @ 3500...
Logs/graph please
