idle issue!..video inside
Old Oct 21, 2011 | 01:45 AM
babaz7's Avatar
im having idle issues,whenever i rev my car when the rpms come down the car tries to die! what could cause this? ive done boost leak test and it looks fine what other things could cause this?
http://www.youtube.com/watch?v=jwcVh8i_8Vc
at 27 seconds you can clearly see what im trying to say!
Old Oct 21, 2011 | 01:52 AM
italianpryd91's Avatar
what kind of bov do you have?
Old Oct 21, 2011 | 02:01 AM
babaz7's Avatar
i have a tial bov
1250cc injectors
MAF with 3" piping from maf to turbo inlet..
Old Oct 21, 2011 | 02:14 AM
check all the vacuum lines, Whens the last time you had a retune. My car use to do the same exact thing. Never fixed it though.
Old Oct 21, 2011 | 02:38 AM
babaz7's Avatar
i checked the vaccum lines and they seem fine,and i tune my self, i think my problem is related to IAC valve maybe it needs replacement but before i do that i want tknow other possiblities,,,anyone here facing same problem and over came it?
Old Oct 21, 2011 | 02:40 AM
babaz7's Avatar
my car is doing this for awile now but recently it got to my nerves as it kept stalling on low rpms while driving...
Old Oct 21, 2011 | 05:40 AM
thedru13's Avatar
My car does the same. Volt test your IAC and see if it's bad. Also your afr at idles was around 10-11 is that normal for you?
Also could be your throttle body seals
Old Oct 21, 2011 | 08:48 AM
babaz7's Avatar
no no my afr's are at 14.7 to 15.0,its just that when i rev they go to 10 and stay there for a few seconds and become normal again...
how do i volt test it? can you plz explain it to me?
Old Oct 21, 2011 | 08:49 AM
babaz7's Avatar
if i clean my throttle body will it help with the issue or is it a waste of time?
Old Oct 21, 2011 | 08:58 AM
thedru13's Avatar
I am on my phone so a pita. Search for threads under my name. You will see and idle thread there is a link on how to test the IAC valve. Can't hurt to clean te TB I also cleaned my MAF sensor
Old Oct 21, 2011 | 09:43 AM
babaz7's Avatar
thanks alot dude, just one thing...can i use wd-40 to clean the throttle body or a lil bit of gasoline cause over here we dont have throttle body cleaner? although we do have carbruretor cleaner if that works?
Old Oct 22, 2011 | 02:27 AM
babaz7's Avatar
bump!
ok can i use carbuerator cleaner to clean my throttle body?
