O-Ringed gead, MAP H11 headstuds
Old Oct 24, 2011 | 08:11 AM
fortyPSIrs's Avatar
I am in need of help once again...
Before I start to put the engine back together I need to know if there is anything special about torquing down a o-ringed head?
The head was already o-ringed when I got the car and engine, but it was off the actual block and missing head studs.
I went and bought some MAP H11 dogpoint studs and am getting ready to put the car back on the road.
Do I use the same torque specs as on a non o-ringed head or is there anything special about it?
I am using a stock head gasket.
I have tried searching but I really didn't find anything, if it has already been answered, please point me the right direction. If it has not any and all help is greatly appreciated.
-Darek
Old Oct 24, 2011 | 12:11 PM
fortyPSIrs's Avatar
Figured it out with the help of Buschur Racing.
The headstuds have to be torqued to 100ft.lbs if you are using a stock headgasket.
I will probably post a "build" thread probably more like a "let's put this thing back on the road" kind of thread.
Old Nov 1, 2011 | 11:43 PM
Slowvac's Avatar
My head is not o-ringed and I torqued my head down to 98lb using a copper gasket using the standard ARP head stud kit (non-L19). So far it is holding well.
Cheers.
