Megan o2 vs Open dump o2 housings
Old Nov 8, 2011 | 07:45 PM
Anubis18's Avatar
I currently have a Megan racing o2 housing and I like it but I'm wondering if there are better gains from using a open dump o2 housing versus a megan racing o2 housing?
Old Nov 8, 2011 | 07:48 PM
binky's Avatar
Here you go:
https://www.evolutionm.net/forums/ev...p-results.html
TL;DR Yes the O2 dump will give you significant gains, especially over the Megan.
-Bink
Old Nov 8, 2011 | 07:59 PM
Anubis18's Avatar
Originally Posted by binky
Here you go:
-Bink
Wow, awesome thanks. That answers that question.
Old Nov 8, 2011 | 08:05 PM
binky's Avatar
Anytime
-Bink
Old Nov 8, 2011 | 08:08 PM
Anubis18's Avatar
Any brands I should look at / stay away from when looking for this?
Old Nov 8, 2011 | 08:12 PM
sparky's Avatar
Those impressive gains were achieved with the Black on larger displacement motors. Don't expect similar gains given a stock 2-Liter engine.
Old Nov 9, 2011 | 05:41 PM
GG06MR's Avatar
I have the Megan as well, and recently picked up a brand new JM Fab O2 dump from a member on EvoM after seeing some of the recent threads, like the one posted earlier, where the O2 dumps owned the merged units. From my research, I would recommend either the JM Fab or the ToxicFab. I hope to have my O2 dump installed by the end of the month, and will be sure to record both before and after VDR results.
Old Nov 9, 2011 | 08:43 PM
danextreyes7's Avatar
o2 dump FTW sounds awesome and better air flow
Old Nov 10, 2011 | 04:31 PM
Anubis18's Avatar
Yeah I actually just bought an EPM o2 dump from a member here on the forums. Thanks for the info guys!
Old Nov 10, 2011 | 04:38 PM
Lyzek01's Avatar
I am really thinking about purchasing an O2 Dump. but I am wondering, do you guys smell fumes in the cabin while on full boost. Cuz I had a small exhaust leak before and the fumes would drive me crazy..
Old Nov 10, 2011 | 04:58 PM
ssg_petty_210's Avatar
There is a gain from running an open dump, but not by much. The good thing about an open dump, is that it eliminates the turbulence from exhaust gases and the wastegate. If you get an aftermarket O2 for an aftermarket turbo, you will see the tube on the wastegate size goes down further so there isnt all that turbulence. Its a good upgrade. I run the Maperformance O2 dump, and I love it. Im sure they will chime in and say a few things about it. If you can deal with the noise it produces, then you should go with one. I for one love the way they sound.
Old Nov 10, 2011 | 05:41 PM
mikeywick821's Avatar
so its just a bolt on replacement?
nothing needs to be changed with the install?
Old Nov 10, 2011 | 07:54 PM
binky's Avatar
Yes this is just a bolt-on install.
However, with that said, you will have to cut a hole in the plastic covering underneath your engine bay (if you still have it on), in order to have the dump tube fit.
-Bink
Old Nov 10, 2011 | 08:21 PM
Rough_draft's Avatar
Any results on the muse o2 dump?
Old Nov 10, 2011 | 08:29 PM
diablo1's Avatar
+1^
