abnormal boost drops at 6k
Old Nov 16, 2011 | 02:06 PM
Yonkers9se's Avatar
im having a rare problem ive never seen anyone face before i dynoed the car previously and the boost was fine but i guess from the load change on the street the boost would die off 6k but not normal it would drop from 21psi to 11 12 psi. i have a aem tru boost in the car and changed the solenoid twice still the same problem i also changed the tb seals and injector seals the car is pretty much stock other then the mods listed below
Old Nov 18, 2011 | 11:17 PM
Yonkers9se's Avatar
bumpp
Old Nov 20, 2011 | 08:46 AM
cfdfireman1's Avatar
stock bypass valve? did you do a boost leak test?
Old Nov 20, 2011 | 08:07 PM
ILoveAWD's Avatar
Boost falling to 11 I think is the computer going in safe mode. Someone correct me if I'm wrong, but either your lines are hooked up wrong or maybe you have a boost leak!
Old Nov 21, 2011 | 08:22 AM
Yonkers9se's Avatar
i did a boos leak test it was fine someone told me of a rare problem with the boost controller if it doesnt get enough voltage that could be the problem with regulating the boost under a more load does that make sense im going to check it today
Old Nov 21, 2011 | 04:52 PM
r.m.s.'s Avatar
you changed the oem boost control solinoid (under the intake area)? You did a vaccum test? How did you do it? And lastly did you just get your numbers or did you get tuned on the dyno?
If you changed the stock boost solinoid, you tested for vaccume correctly and it didn't fix the problem then you should talk to your tuner.
Old Nov 21, 2011 | 04:55 PM
MiTech's Avatar
we fix the problem guys thanks noting but bosst leaks haha :-)
Mike
Old Nov 21, 2011 | 10:15 PM
Yonkers9se's Avatar
It's a stock boost solonoid caped of to a ebc but idk doesn't run properly im goin to install a hall an see if it helps it only happens periodically it's wierd.
Old Nov 22, 2011 | 09:09 PM
Yonkers9se's Avatar
bump think im going to a hallman too many problems with the aem
Old Nov 29, 2011 | 10:51 PM
Yonkers9se's Avatar
still happing on the higher rmps 6500 7000k dies and lowered the boost to 21-22 anyone ever have this problem could it be stock uicp or bov
Old Dec 16, 2011 | 08:20 PM
did you check your spark plugs?
Old Dec 17, 2011 | 12:13 AM
Yonkers9se's Avatar
Yea I fixed it turned out with was the stock snorkal I was too lazy to tie it down to the bumper rare problem but its fixed ty
