txs bov users
Old Nov 20, 2011 | 08:25 PM
211Ratsbud's Avatar
txs bov users
Have you guys ever done a boost leak test while using your txs bov? I'm running vta on stock ecu SD, and I've heard these bov tend to leak. Also worries me that txs gives 25 psi as the threshold for certain types. Is that related to the spring tension or piston surface area on charge pipe side ?
