water pump fail again...PLS HELP
Old Nov 29, 2011 | 08:44 PM
barneyb's Avatar
Originally Posted by tscompusa
Yep BTK is whats on mine also. can we find these direct below dealer prices or is it pretty much impossible?
did you write all that info in your own words or are you going off a 3rd party?
if in your own words then you know a crap load about how the pumps designed.. and based off what i just read, welding the weep hole shut will lead to a catastrophe if you will.. a seized up pump correct?
No, these are just my thoughts. At one point in life I was a chemist and chief operator at a brown trout farm (also known as a wastewater treatment plant). Not a career path I would necessarily recommend. But, we had a lot of pumps.
Anyway, the weep hole is there to keep coolant from going through the bearing. Now, a wet bearing might seize or maybe start to disintegrate and get loose. You don't want grease mixing with water. Sometimes when the seal leaks it is because the bearing went first and allowed the shaft to wobble. Another thing to consider is that the ceramic seal is just two flat rings rubbing against each other, a tiny bit of leakage can be normal.
Old Nov 29, 2011 | 09:33 PM
tscompusa's Avatar
would you be interested in looking at a bad pump i have here and giving us more of your thoughts on whats happening? if so ill send you one.. you seem to be more knowledgeable then most on here about this stuff and considering your background job career i feel you could share a lot of information about the pump if you taken one apart.
Old Nov 30, 2011 | 01:52 PM
barneyb's Avatar
I slept on your offer and still don't see what can be achieved by tearing down what is a throw-away part. It is unfortunate that the water pump on our cars requires considerable work to change out. However, with the under hood packaging now-a-days, this is true for some parts on any car.
All, I can suggest is that, at the time of purchase, you seek some assurance of warranty and keep the receipt.
Old Nov 30, 2011 | 02:19 PM
n2oiroc's Avatar
so the shaft rides on sealed bearings. where is the mechanical seal?
Old Nov 30, 2011 | 03:52 PM
bigben's Avatar
I'm sure glad I read this yesterday. I did a timing belt/water pump change about 2 years ago and it's always leaked some coolant, of course all the parts I used were aftermarket, not oem. Anywho, I went with a Mishimoto radiator about 3 years ago, and I noticed that it has a 19psi radiator cap. The oem one is 1.1bar, or 16psi. I thought it was weird that everytime I would top off the radiator and refill the overflow tank up to the specified mark, that it would be back down to where it normally leaks out to within a few days. I guess because the radiator cap had a stronger spring that it wasn't opening like it was supposed to, building up extra pressure, and then leaking out of the water pump.
So, I put the oem radiator cap back on, and we'll see how it acts. I sure hope this fixes the problem, even though I am going to do the timing belt/water pump again sometime next year.
Old Nov 30, 2011 | 09:46 PM
drb's Avatar
drb
The OEM pump, at least the one that came off of my car, was made by BTK, a Japanese company headquartered in Tokyo. However, their oil pumps and water pumps can be found on vehicles worldwide including American makes.
The pump has a ceramic seal. These first appeared for large industrial pumps, as I remember, back in the 70's and were an expensive upgrade. The seal consists of two ceramic flat rings that slide together, one stationary in the housing and the other on the shaft, their mating surfaces pressed together by a spring. Large industrial pumps, depending on what was being pumped, required what was called gland water, clean water pumped into the seal area at a pressure higher that what the pump was capable of producing. The reason for this was that any particle harder than ceramic that managed to work its way between the sealing surfaces would cut them to pieces. The ceramic material is so hard that the surfaces can rub together at the speed the pump operates at and not wear out for many thousands of miles on a car if not contaminated.
I remember the pump that was used on my DSM twenty years ago and all it had was a hole that went directly into the area between the seal and the bearing. The Evo pump has two weep holes (if they are both drilled into the interior) so evidently the pump is used in another application and mounted differently. But instead of a hole there are passageways along the pump housing that are apparently to bring any leaked antifreeze to the outside of the timing belt area.
So, what you have going from the inside to the outside of the pump is impeller, ceramic seal, weep hole and bearing. The bearing is also sealed but the seal is to keep out dirt from the outside and keep out coolant, not under pressure, from the inside.
So, having a sealed weep hole on a failing water pump means that first the seal would leak a little and then the space between the seal and the bearing would fill and eventually the coolant would work its way into the bearing. Then the bearing would fail. This would occur even if the seal was leaking so little as to not otherwise cause a problem.
I agree with all that you have said with one exception. For an automotive water pump one of the mechanical shaft seal faces is probably ceramic and the other is normally made out of carbon graphite. Both seal faces are lapped extremely flat which makes it difficult for water/antifreeze to pass between them. The seal faces are lubricated and cooled by a boundary layer of water/antifreeze between the faces that can be measured in micro inches. All seals of this type leak, although the normal leakage rate is very small, and it is normally classified as non visable. You definately don't want to plug the weep hole between the seal faces and the bearing/lipseal, because as you said the weep hole is there to funnel the normal seal face weepage away from the bearing.
Old Nov 30, 2011 | 09:51 PM
drb's Avatar
drb
The mechanical shaft seal is between the bearings and the impeller.
Old Dec 1, 2011 | 12:34 AM
alexui90's Avatar
ok..i bought oem pump, oem belt, oem thermostat, oem radiator cap and ''PEAK'' antifreeze..wish me good luck...=]
THANK YOU ALL GUYS...I APPRECIATED
Old Dec 1, 2011 | 02:00 AM
tscompusa's Avatar
! good catch man. ya definitely stick with the oem cap or a 1.1 bar rated cap. im sure it will fix your issue.
Old Dec 1, 2011 | 02:02 AM
tscompusa's Avatar
thanks Dan.. more great info.
Old Dec 1, 2011 | 02:04 AM
tscompusa's Avatar
no problem. yep, i hate the location of it. i am definitely going to report it if it happens again.
Old Dec 1, 2011 | 02:09 AM
tscompusa's Avatar
you should be just fine, just remember to let the car warm up to a good operating temp before you decide to boost it hard. if it continues to happen though and you're confident the head studs are torqued down properly then i would be concerned with the tune being possibly to aggressive.
also put some rtv on the gasket and put it on the pump.. do it a good few hours before you install it.. that assures the gasket cant move or get torn during install. just a tiny thin layer that you can still see through.
also make sure you get all the air bubbles out and burp it good with a funnel similar to that yellow Lisle one.
Old Dec 1, 2011 | 09:34 AM
barneyb's Avatar
Thanks for the help. That, and your explanation of how the seal works is much better than my attempt.
I don't see the pressure cap being all that important. Sure, more pressure is going to make a leak bigger but a leak is a leak. Below the sealing surfaces is a spring and bellows. A manufacturing defect there may also cause a leak.
Old Dec 1, 2011 | 04:26 PM
tscompusa's Avatar
well i don't agree with this. if you have a 21psi cap then you're going to pressurize the system to 21psi.. the radiator cap is what regulates how much pressure the system can hold up to. a 16psi cap the system sits at 16psi cold. start doing a pull with a 21psi cap and see what happens to your water pressure.. a higher rated cap is going to cause excessive water pressure spike which is the exact opposite of what we are trying to do here.
there's no reason to go above 1.1 bar in a evo to my knowledge with the radiator cap. have the radiator cap stick shut once and see what happens.. surely it will take the waterpump out and whatever lines it decides to blow with it.
if you're starting at higher psi its going to hit a higher psi target.. the pump helps create pressure build up when it spins faster. i have logged this with my water pressure gauge.. the initial WOT always creates a little psi climbing.. so if you're starting at higher base psi its just going to help make the problem worse.
Old Dec 2, 2011 | 08:26 AM
drb's Avatar
drb
Here is a decent video showing the purpose of the weep hole. Shows a Lancer water pump, but the same principle applies to the EVO:
http://www.youtube.com/watch?v=zGbY71uo4ZA
